Clutch problems!!!! Help!!
Old Feb 16, 2012 | 02:00 PM
Jonnyd42246's Avatar
[B][I]Ok so this morning i was pulling into a parking spot and i was straightening my rx8 out and when i pushed in the clutch its making a grinding noise, the clutch has been tight since i bought it 2 weeks ago.. and now today when i push it in its making a grinding noise and slight vibration... does any on know what this is? i have an appt to drop it off to my dude to replace the clutch if thats what it is for $550, with resurfacing flywheel....can anyone help me please???!?!?!?!
Old Feb 16, 2012 | 02:04 PM
RIWWP's Avatar
There appears to be a problem with the italics and bold selections when you post. See if you can correct that next time.
So, you hear some grinding noise when you push the clutch pedal in. Have you checked to see if the clutch pedal broke? Common problem, and covered under a 100,000 mile warranty from Mazda (just the pedal). If not, then it's likely a bearing issue. The clutch itself is disengaged when you push the pedal in. So if there is only grinding when the clutch is disengaged, it's not going to be a clutch wear or flywheel resurfacing issue. If it's a bearing, it's likely the throwout bearing, which is used in the disengaging process.
It's also possible that it's the transmission, not the clutch, but we would need more accurate information from you.
Old Feb 16, 2012 | 02:06 PM
i havent checked the pedal just yet...but i will as soon as i get outta work..... what will i be looking for? and also would this cause the grind when i press it in?? thanks for the help
****no italics or bold** lol
Old Feb 16, 2012 | 02:11 PM
RIWWP's Avatar
Side-to-side flex is the most common break, though there are several. Depends on exactly how the pedal assembly welds fail. If you get down there and grab it with your hand, you shouldn't be able to appreciably flex it side to side at any point in the range of normal motion, and the motion as it's being pushed in should be completely linear. If it twists or curves, it's broken.
Old Feb 16, 2012 | 02:14 PM
thanks alot for the help!!! i will do this in about 2 hrs when im off work!
also would this cause the grinding noise when the pedal is being pushed all the way in....prior to this happening the clutch was really stiff and was gritty feeling when i would push the pedal in...could this have been an upcoming sign of breakage, and or clutch failing?
Old Feb 16, 2012 | 02:16 PM
RIWWP's Avatar
Is the grinding from the motion of the pedal itself? Or it just becomes heard once the pedal is all the way in? You aren't really clear about that. The specifics of what happens when are important clues.
Old Feb 16, 2012 | 02:20 PM
when i push in the clutch, even just a little, it is stiff all the way down, and when i reach the point of where the clutch is pushed all the way in so i can shift through gears, is when the grinding and slight vibration in the pedal occurs... it sound terrible... and made it hard to put into gear...
Old Feb 16, 2012 | 02:23 PM
RIWWP's Avatar
You said "made it hard", A) is it easier if you back off the pedal a bit? Or B) do you mean "it doesn't get easier"?
If it's A, it's likely the pedal. If B, then it's likely your throwout bearing.
Old Feb 16, 2012 | 02:27 PM
its hard both ways, in and out... would the throwout bearing cause the grinding, or were you just referring to the stiffness?
Old Feb 16, 2012 | 03:12 PM
RIWWP's Avatar
Maybe I can explain it a different way, because the terms you are using are ambiguous.
You stated: "where the clutch is pushed all the way in so i can shift through gears, [...] and made it hard to put into gear"
Well, before the clutch pedal is the whole way in, you CAN'T put it into gear (unless you are rev matching, but I'm assuming that isn't the case here).
The words "made it hard" imply that it was easier before that point. I'm trying to figure out where it is easy to put it in gear, or if you mean "harder than it should be"
WranglerFan
May 31, 2022 07:51 AM
GARCIAC951
Sep 10, 2015 07:17 PM
ed0128
Sep 9, 2015 04:50 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
