Back pressure
Old Feb 15, 2012 | 10:07 PM
sabbath39's Avatar
Back pressure
I'm kinda new to the RX8 and whole rotary concept. About how much back pressure does the rotary need to make optimum power? If any at all.
Old Feb 15, 2012 | 10:08 PM
Brettus's Avatar
Boosted Kiwi
Originally Posted by sabbath39
i'm kinda new to the rx8 and whole rotary concept. About how much back pressure does the rotary need to make optimum power? If any at all.
11.5
Old Feb 15, 2012 | 10:10 PM
paimon.soror's Avatar
Repeating, not just .5
Old Feb 16, 2012 | 08:56 AM
sabbath39's Avatar
thanks
Old Feb 16, 2012 | 09:09 AM
RIWWP's Avatar
Brettus, is that 11.5 psi, lbs/sqin, newton meters, or gargefarks/ft?
Old Feb 16, 2012 | 09:10 AM
bse50's Avatar
#50
engines, not just rotaries hate backpressure.
Now talk about exhaust volume, speed, pulses, scavenging etc and your question may start to make sense.
@riwwp: i read garagefarts/ft... time for new glasses?
Old Feb 16, 2012 | 09:24 AM
RIWWP's Avatar
I love how he took the number as an answer without even a unit of measure. Shows that he really knows nothing about the term other than how to spell it.
Once he educates himself on the term, he can come back and find out that this isn't a piston engine, so everything he just learned is useless.
Old Feb 16, 2012 | 10:00 AM
warren(silver-roxy-8)'s Avatar
no sleep til it spools
As I understand it, piston or rotary, no engine needs or wants backpressure.
Edit: bse50 already said that....my bad.
Old Feb 16, 2012 | 10:09 AM
RIWWP's Avatar
Correct.
Old Feb 16, 2012 | 12:55 PM
Brettus's Avatar
Boosted Kiwi
BSE is quite correct . 11.5 garagefarts/ft is the optimum .
Old Feb 16, 2012 | 06:00 PM
sabbath39's Avatar
Well considering I've been building V8s for nearly 7 years now in my free time, and also work on and off in the maintenance bay working on HMMVW's for the army I'm sure I really don't. But I guess that doesn't matter. Forgive me for trying to learn this engine.
Old Feb 16, 2012 | 06:22 PM
PhillipM's Avatar
I aim for 4 metric sheep/hp^2
Old Feb 16, 2012 | 06:50 PM
RIWWP's Avatar
I have zero problem with someone trying to learn. Anyone can back up my reputation there. What I don't understand is IF you know what back pressure actually is (since it's a misnomer) AND are attempting to learn how a rotary engine can be affected by it, why did you approach the question that way, and then apparently accept a response that could not possibly give you the starting point you were looking for?
Take whatever field you are knowledgeable about, and then assume you have someone that comes to you and asks you a question about what you know, but asks it the way you asked the question here. How would YOU respond?
Take a good look back over your opening posts. If you really know what backpressure actually is, how could that question give you an answer that is usable? So, even if you didn't mean it that way, we can't see that intent, and make the assumption that you have no clue what you are doing, and are yet another kid walking into the river without being able to swim.
Which we see.
Every.
Single.
Day.
So approaching it this way kills any motivation for us to assist you in your self education.
So maybe you would like to try again?
Old Feb 16, 2012 | 07:46 PM
sabbath39's Avatar
Well I understand why yall were sarcastic, I have to deal with younger soldiers who don't know much. I'd guess a better way to ask my question is I'm planning to make a custom exhaust for my 8 and I'm trying to figure what diameter piping I need to use, if I need to put any extra bends in the piping or keep it as straight as possible.
Old Feb 16, 2012 | 08:12 PM
RIWWP's Avatar
As big and as straight as possible. No scavenging for the rotary. Dump to atmosphere is technically the best possible in terms of power, but the noise can be ... painful.
Old Feb 16, 2012 | 09:44 PM
Brettus's Avatar
Boosted Kiwi
As big and as straight as possible. .
That's what she said !
But how many garagefats/ft ?
Old Feb 17, 2012 | 08:06 AM
RIWWP's Avatar
Depends on the lunar bean per mile consumption rate.
Old Feb 17, 2012 | 08:41 AM
200.mph's Avatar
FULLY SEMI AUTOMATIC
unbolt the exhaust mani and remove everything that is connected to it. free flowing and saves weight. might want to remove the hood also and buy some earplugs
Audio Concepts ATL
Sep 26, 2021 01:59 PM
drebbrnator
Dec 27, 2018 07:02 PM
uZu
Dec 30, 2015 12:35 PM
9krpmrx8
Nov 5, 2015 11:45 PM
Sifu
Aug 30, 2015 10:51 PM
