HEEEELP P0171 code
Old Feb 13, 2012 | 11:43 AM
jordanjerome's Avatar
ruthless8
Angry HEEEELP P0171 code
OK I have an 05 AT...yes I said auto so dont judge me... Anyway I have the Racing Beat Intake, exhaust, hollowed out CAT. If I try to go WOT it bucks like a horse and bogges out then shuts off and throws a P0171 code. I recently changed the coils and checked the MAF sensor and its clean. After a few mins the car starts back up and runs a lil but will lose power and shut off if I try to press down on the gas it sputters and shuts off again. Could it be the fuel pump or injectors? The code says running too lean in bank 1.
Old Feb 13, 2012 | 12:30 PM
Chavy's Avatar
I did it for the lulz
how many miles on the engine? sounds like it's on its way out...
Old Feb 13, 2012 | 01:05 PM
xexok's Avatar
This thread should have all you need to diagnose your problem.
https://www.rx8club.com/series-i-trouble-shooting-95/cel-p0171-223935/
Old Feb 13, 2012 | 03:19 PM
8ya's Avatar
8ya
been Dealing with the same issue.. keep us posted.
Old Feb 13, 2012 | 04:26 PM
ruthless8
The car has 168859 miles on it, 3rd motor so the Motor only has roughly 30k on it, However everything else is all original miles except plugs, wires coils. One "STEALERSHIP" told me that he thinks its the O2 sensor because I told him that I had no CAT, up here they dont smog and dont ask questions. They aslo said that todays ECU's are so complicated that if the CAT was hollowed out that the ECU is getting mixed readings from the O2 Sensor so its over compensating so its going to make it run bad. Again I call BS because several people go without a CAT and theirs run fine. I have cleaned the MAF sensor and still having issues. GRRRRRR
Old Feb 13, 2012 | 04:49 PM
8ya's Avatar
8ya
I got both o2 sensors changed and it fixed my p0171 for about two months. Then it came back with a vengeance. Might be worth a shot.
Old Feb 13, 2012 | 05:54 PM
StealthTL's Avatar
Metatron
A lean condition can also be caused by a clogged fuel pump pickup (I know, it's my favorite diagnosis, but also common - and more important, free!)
Old Feb 14, 2012 | 09:42 AM
ruthless8
So if I am not mistaken, thats the sock thing on the pump? I thought about that as well. I could just take and replace the pump, and O2 sensors and see if that works. I do know that there is no vacuum leak because I checked all the hoses yesterday. This is why I miss cars back in the day that a monkey could work on. Todays cars you need a College degree to even start lol.
Old Feb 14, 2012 | 09:43 AM
ruthless8
Since my cat is gutted will it run if I dont put the sensor in?
Old Feb 14, 2012 | 11:00 AM
I would check for a fuel delivery issue as well. That code can be a vac leak as well, but that wouldn't account for the higher load stuff
Old Feb 14, 2012 | 11:26 AM
xexok's Avatar
Check the thread I linked to above if you have not already. If that thread cannot help you then you may just be SOL.
It has many good things in it, this picture being the best part probably.
Old Feb 14, 2012 | 12:03 PM
ruthless8
Thanks I checked that and took it to the Mechanic to use as a diagnosis reference. Since I am military he is giving me a free diagnostic test to find the problem. I will update everyone and thanks for the advice in advance.
Old Feb 16, 2012 | 02:23 PM
8ya's Avatar
8ya
Updates??? Mine has been at the steeler for a week and no diagnosis.
Old Feb 23, 2012 | 05:28 PM
ruthless8
Still no updates and now my optima battery is dead grrrrrr FML.
Old Feb 23, 2012 | 07:45 PM
550rwhrex's Avatar
FL
I'm having the same problem, tomm I'm changing out the fuel pump unit, hopefully it's that.. Ive checked the cat,nothing! I changed the coils three months ago, checked every vacuum hose, all is in good shape, cleaned maf,ecc shaft sensor and nothing so far..will post after I change the unit.
Old Feb 24, 2012 | 01:00 PM
8ya's Avatar
8ya
So....after three weeks I got a call from mazda....and they did some "work" on the injector o rings and cleaned my injectors... and it cleared the code. For now.....
Old Feb 27, 2012 | 06:40 PM
ruthless8
So now I installed the battery, it ran like a champ, for 15 mins now shuts off every time I come to a stop or don't hold my foot on the gas. Grrr
Old Feb 29, 2012 | 09:46 AM
8ya's Avatar
8ya
That's what my car did when it lost compression with the po171 code. Might want to check that don't know what year you have the the warentee on 04s expires this year.
Old Mar 1, 2012 | 10:41 AM
VOODOO8's Avatar
Hermitage Holdout
Try this, go to google.com and enter the following in the search field: site:rx8club.com battery change stall.
Old Mar 1, 2012 | 06:27 PM
ruthless8
Update
So the battery was part of the reason why the P0171 code was popping up because bad battery was not able to fully power everything so now that the new battery is installed the dealer did a diagnostic and the VDI solenoid under the intake is not working so it's allowing too much air in ergo the running lean in bank 1 or P0171 code. But here is the kicker, according to Mazda since I have the lower powered rx8 or the AT and not the MT rx8, instead of just replacing the solenoid for only $118 I have to replace the whole freaking intake manifold at a cost of $1200! since on the auto version the manifold and solenoid are 1 piece. FML so on a side note after I get the car fixed and cut off the arm and leg to pay for it, I am done with this car and Mazda and will be getting rid of it. Have had way too many problems with this car that any other car company would have recalled. 3 motors and over $20k in repairs to a faulty vehicle have left a bad vibe with me and the car and it's maker.
Old Mar 1, 2012 | 08:51 PM
Smells like a pile to me
Old Mar 3, 2012 | 10:54 AM
8ya's Avatar
8ya
So just got my car back from mazda after 5 weeks and they said that my fuel injectors were cutting out so they changed the gaskets for the fuel injectors... cleaned the maf and cleaned the intake.
Old Mar 3, 2012 | 11:15 AM
So basically they fixed a small vacuum leak Likely if they would have tested for that at the start they could have saved you about 4.5 weeks at the shop
Old Mar 3, 2012 | 11:40 AM
8ya's Avatar
8ya
Yes i agree! They said that air was leaking around the injectors, since the gasket was worn out. They also said the injectors were pretty plugged up. Taking the intake apart and cleaning the maf was the first thing they did and it fixed nothing.then they tested plugs and coils. Then changed the gaskets on the injectors. And that cleared the code. Also had to get the reverse switch on the tranny replaced because it was leaking. And a brake like that was leaking. No fun!
Old Mar 3, 2012 | 12:22 PM
ruthless8
Like I said my car has givin me more problems then any other car so I am done with it.
