Oil pooling btwn intake runners
Old Feb 12, 2012 | 08:24 PM
AMCsellout?'s Avatar
Question Oil pooling btwn intake runners
Oil is slowly pooling on intake manifold between the runners. There appears to be an injector of some sort on intake above oil puddle. Oil is also lightly sprayed on wiring harnesses behind alternator. I can see the external oil lines across top of engine block, they do not appear to be leaking in that area. Is this injector (just below 2 vaccume diaphrams) on intake for oil? Any ideas where oil is coming from? Any help is welcome.
Old Feb 12, 2012 | 08:49 PM
Ricky SE3P's Avatar
Project Seca
try to get photos as some may get confused with your explanation. it will also help diagnose the severity of your issue
Old Feb 13, 2012 | 12:24 AM
yea,
got to say photos,, i a might be in that area this weekend.. might be able help.
but really photos..
Old Feb 15, 2012 | 09:05 PM
I'm working on the photos. The leak isn't bad. I'm just curious where the oil is coming from. I cleaned up the oil last July/Aug and thought it was some how spilled there. So it has been several months for it to accumulate to where I could smell it when the engine was hot. I'll post pics this weekend when I have some time off work. Thanks
Old Feb 18, 2012 | 03:07 PM
OK, I have some pics. But I've no idea how to post them. They're on my computer not a website. I'll search for a way to upload.
Old Feb 18, 2012 | 03:44 PM
Easy_E1's Avatar
"Go Advanced" "Manage Attachments" "Browse" Click pic of your choiice. Close window. "Submit Reply".
Sounds like a broken Oil Metering line.
Old Feb 18, 2012 | 04:23 PM
Thanks, this is where the oil leak is, the oil seems to mist and eventually pool between the intake runners. I can see what looks like a banjo type fitting w/ an external oil line nearby and that maybe the cause.
Oil pooling btwn intake runners-2012_0218rx8_oil_leak0005.jpg Problem is behind alternator
Oil pooling btwn intake runners-2012_0218rx8_oil_leak0010.jpg below the vaccume diaphrams
Oil pooling btwn intake runners-2012_0218rx8_oil_leak0009.jpg You can see the remnants of dried oil
Oil pooling btwn intake runners-2012_0218rx8_oil_leak0011.jpg The surrounding area has an oil film on it
Old Jun 18, 2017 | 12:13 PM
TheWaldo's Avatar
What did you find the problem to be? I have oil pooling on top of the lower engine between those runners. I also have a slight ticking knocking sound like a stuck lifter or the such. Car drives fine....just makes a noise. Cranks right up, etc. About to investigate the problem this week.
Old Jun 18, 2017 | 09:48 PM
NotAPreppie's Avatar
What am I doing here?
It's probably spilled oil during the refill phase of an oil change.
The ticking sound is probably the SSV or VDI actuators.
Old Jun 20, 2017 | 09:46 PM
The leak on my car is from an oil nozzle. There is a gouge on the machined surface where the nozzle seats to the engine. I filled the gouge with epoxy and the leak has slowed but is still there. Check your oil lines to the nozzles for cracks as they get brittle over time.
gwailo
May 14, 2024 06:57 AM
TJSiegrist
Sep 10, 2015 09:29 AM
Slack
Sep 5, 2015 06:42 PM
chris424
Sep 2, 2015 10:18 AM
wayloco
Sep 1, 2015 09:03 PM
