Glove box noise? Help identify what's this part?
Old Feb 11, 2012 | 01:20 AM
szjalo's Avatar
Hi. I have a 2005 RX8. and the car always has a light noise coming out from the glove box (when driving, especially on bumpy road). Whenever I use my finger to lightly push the glove box the noise disappears immediately. I've been trying to figure out what's wrong there but so far all I can find is a broken part below (attached)
Basically it has a loop-like thing which is hooked on the edge of glove box. like this
Mine has the loop broken and no longer can hold in the right position. I am not sure if this is the source of the unknown noise. What do you guys think?
If this is the problem any one knows what's the technical name of it? Can I find a used/new part anywhere for it?
Thanks a lot
Attached Thumbnails Glove box noise? Help identify what's this part?-12121.jpg
Old Feb 11, 2012 | 02:25 AM
Grace_Excel's Avatar
Charles Bundy
Glove box actuator. I just bought one since mine didn't come with it. You could remove it and leave the glove box without one or replace it. Don't ask me how, I'll only know once I receive my replacement.
Old Feb 11, 2012 | 11:25 PM
monchie's Avatar
I HATE SPEEDBUMPS!
I have the same issue as well. What i did to reduce the noise is i inserted a few folded paper just enough to still close the glove box, and the noise went away.
Old Feb 12, 2012 | 03:10 PM
szjalo's Avatar
I removed the thing but the noise is still there...So I don't know if I should pick up one for the glove box. So only one is enough? both sites have the bump thing to hook the loop?
Old Feb 12, 2012 | 03:12 PM
szjalo's Avatar
Well I tried this before, I used a piece of foam to insert into the slot. but didnt think it works. And over time, the foam is pliable and became more and more flatten. so don't know any insert can help ..LOL
Old Feb 13, 2012 | 10:52 PM
Charles Bundy
I guess it does need two, however, could your noise be caused by an object in your glove box like some loose item or even the lock stricker or the latch handle? The glove box can be removed by pressing the sides releasing the tabs then unhook it off comepletely. Try removing it and check if there's something internally loose as well.
Old Feb 14, 2012 | 10:43 AM
JTtheDude's Avatar
I have the same problem, I've noticed that the left side of my glovebox hangs slightly lower than the right side but I've never inspected the hooks being mentioned here, and slight pressure on the left side of mine the noise stops. I've also noticed more noise when I'm at a stop in gear vs neutral. I'm AT and when I'm at a stop in D or M there's quite a bit of shaking but I think my right side broken motor mount is adding to the issue in my case and once I put it in N the noise stops.
Old Jun 30, 2020 | 04:48 PM
Rusty101's Avatar
TN Glovebox Rattle FIX!!!
I know this is a SUPER OLD thread, but I found the fix for this on my RX8 a few years ago. The issue isnt the glovebox to the dash, or the glovebox actuator. It is actually the GLOVEBOX ITSELF!!!
My cabin had A TON of noise in it, and I hunted EVERYWHERE trying to figure out where it all was coming from, and eventually landed on the glovebox. I'm assuming its for crash safety, but the glovebox is actually a shell of inner and outter parts. In between those layers there's a hidden sheet metal piece (likely to lessen leg injuries in a crash for the passagener). This metal piece rubs against the inner and/or outter pieces, and can cause a hell of a lot of noise!
TO FIX: Take out the glovebox, take off the glovebox handle, then you can see the internal sheet metal shield. Get some Great Stuff or spray foam equivalent, shoot it all up in the gaps inside the glovebox! Clean off any excess with some Acetone or cleaner called out on the foam label, put the handle back on, and reinstall.
Hope this helps someone else out who HATES unecessary rattles taking away from the sweeeeeeet sounds of some Dorito Power!
mr. GrandGame
Sep 9, 2025 10:41 PM
AllSeeingChris
Aug 16, 2015 12:35 PM
eazzyg
Aug 10, 2015 10:32 PM
MolecularConcept
Aug 1, 2015 03:15 PM
