what did YOU pay for programming keys and/or ABS at the dealer?
Old Feb 9, 2012 | 09:37 PM
Ricky SE3P's Avatar
Project Seca
Question what did YOU pay for programming keys and/or ABS at the dealer?
Alright basically what the title reads. What did YOU pay for programming/reprogramming your keys to your pcm, and/or your abs unit at the dealer? I'm doing the AT to MT swap and have all the parts EXCEPT the engine, trans, and 6 port pcm.
I would like to get an average idea of what others spent getting keys or their abs controller reprogrammed to give me an idea of the cost for each to decide the most cost effective route for myself (again, cheapest not easiest)
1) Either buying the pump from the same car the pcm came from, or reprogramming my existing abs module
2) Having Mazda reprogram all my keys to the new 6 port pcm; OR getting a pcm with at least one key and have a locksmith code my set
Flame all you want about "wasting money" on the swap, I only spent $370 getting all the parts needed for the swap besides the drive shaft, engine, transmission, and pcm. Plus it is my money, I'll do as i please with it and im doing the swap for the experience more than anything else.
Please, just help me out by answering my question. This thread could also help others know what they should be spending on this kind of service at both dealerships and locksmiths. Thank you
Last edited by Ricky SE3P; Feb 9, 2012 at 09:38 PM. Reason: bold and underline main subject to help keep posts relivant to thread
Old Feb 10, 2012 | 12:55 AM
the ecu between the auto and the manual tranny are not the same. it is not just a simple program the keys or abs..
you are going to need friends.. programing the keys is a diy here.
Old Feb 10, 2012 | 05:30 AM
Ricky SE3P's Avatar
Project Seca
I believe you didnt correctly interpret my first post... Im aware they are different, and i still need to buy one. I also know about the programming key diy and thats not what im asking about. Im asking about my options for programming when it comes to my keys and abs unit to the 6port pcm once its installed.
Old Feb 13, 2012 | 07:52 PM
Ricky SE3P's Avatar
Project Seca
bump; anyone??
Old Feb 14, 2012 | 08:11 PM
Ricky SE3P's Avatar
Project Seca
nobody?
Old Feb 14, 2012 | 08:40 PM
RX8RX7's Avatar
with Dealer's IDS, it takes less than 15 minutes to do key programming, all they need to do is delete existing code stored, and accept the new ones. You can actually do it if you have the equipment at a Ford dealership and your PATS info, which can be obtain from Mazda for I think 35 bux (unlimited inquires for a day or 72 hours, forgot)
As for ABS module, it should be about the same, they just need to do the "learning" part. and communicate with the rest of the system.
Old Feb 14, 2012 | 09:02 PM
Ricky SE3P's Avatar
Project Seca
so on the safe side i could say $100 to get all my stuff (keys and abs module) reprogrammed? thats great news! And thanks for that information ill need to take to the dealer to get the correct info/data for my purposes and not get screwed over by mazda. really appriciate it
Eraser
Aug 11, 2023 11:31 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
stickmantijuana
10
Sep 13, 2015 11:28 PM
