clutch problems
Old Feb 5, 2012 | 09:48 AM
aftermarket-RX8's Avatar
clutch problems
does anyone knows what some signs of a bad clutch slave cylinder are? A few weeks ago, my clutch pedal stopped returning to the to the unpressed position and now my clutch doesnt engage completely. I think it might be the clutch slave cylinder or master cylinder, but im not completely positive about it. If anyone can help me out here, i would appreciate it. Thank you.
Old Feb 5, 2012 | 09:53 AM
wcs's Avatar
wcs
no agenda
What year is your 8?
The SI models had lots of problems with the Clutch peddle bracket actually breaking.
Old Feb 5, 2012 | 09:57 AM
Old Feb 5, 2012 | 10:00 AM
wcs's Avatar
wcs
no agenda
Get down there and check that bracket.
https://www.rx8club.com/showthread.p...peddle+bracket
Old Feb 5, 2012 | 10:02 AM
i did. there doesnt appear to be anything wrong with the bracket.
Old Feb 11, 2026 | 09:51 PM
Rafaelgaz's Avatar
Clutch won’t return to back as it should
Lost clutch during a drive today. It simply stayed buried all the way down
Old Feb 12, 2026 | 04:25 AM
mazdaverx7's Avatar
RX-Heaven
Check the clutch pedal to ensure it hasn't snapped at the welds. Often the clutch pedal can **** to one side slightly if the welds are failing. If the pedal and bracket are OK, you will want to look for leaks st the clutch slave cylinder and master cylinder. If you do need to replace one, its a good idea to replace the other as a preventive.
Old Mar 25, 2026 | 12:10 AM
S2GT's Avatar
Would anyone happen to know if the clutch pedal is the same for RHD and LHD ?
WranglerFan
May 31, 2022 07:51 AM
GARCIAC951
Sep 10, 2015 07:17 PM
ed0128
Sep 9, 2015 04:50 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
