Power Steering Failure help.
Old Feb 4, 2012 | 04:46 PM
sauceyI986's Avatar
Now before you all say search I been there and done that's already*
Right now my power steering completely out and I get now response with EPS at all. *I do know that my power steering was working before I pulled my motor and now that the car is up and running its a no go. I cleaned and check all the connections over and over again and no luck any suggestions...?
Old Feb 4, 2012 | 04:52 PM
The fuse is OK?....
Check power at the relay under the ECU....
Check the connectors there if you had the ECU out as well...
Old Feb 4, 2012 | 04:53 PM
wcs's Avatar
wcs
no agenda
Have a look at the connectors .. they are basically underneath the coolant bottle and if that thing spues some **** it will cause issues.
BTW does your car ever work?
Just wondering?
Old Feb 4, 2012 | 05:05 PM
sauceyI986's Avatar
The connections are right in front of me as I disconnected them all and cleaned them and i also have the steering wheel with the exclamation point Lit up on my dash as well.
Old Feb 4, 2012 | 05:07 PM
Huh?.....
Old Feb 4, 2012 | 05:09 PM
wcs's Avatar
wcs
no agenda
Wait ... are you just getting a light or have you actually lost the power steerring?
If you start the car and turn the steering wheel all the way to the left then to the right it should reset the traction control light.
Old Feb 4, 2012 | 05:10 PM
sauceyI986's Avatar
Unhappy
Just wondering?
After being down for 2 years there is so much **** to get right again. Seem like I always having issues.
Old Feb 11, 2012 | 12:16 PM
sauceyI986's Avatar
Bump
Old Feb 11, 2012 | 09:54 PM
Bori Rx8's Avatar
Check the ground that goes under the air filter box.
Old Feb 12, 2012 | 05:24 PM
sauceyI986's Avatar
Ok. Since I redid sor of the connections were would be the proper grounding point go. Because I know when I had the grounding point wrong for the factory stereo system the stereo wouldn't come on at all.
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
Fickert
Sep 9, 2015 01:21 PM
Tsurugi
Sep 7, 2015 08:27 PM
