Warranty information clarification
Old Jan 31, 2012 | 04:12 PM
Dark_Rider2k3's Avatar
Today I got a print-out of the warranty information on the RX-8 I purchased:
I was mainly curious about the 4206F recall. I noticed on my report it has a lot of 4206F information. One says rental vehicle, PCM reprogram, another says Cust. Fuel Re (what is that?), and Cust. Vehicle.
I just want to clarify what each of those are. I know that for the recall Mazda did a compression check and test of the motor, and if you failed you got a new one. So I'm curious as to what all that means.. did I get a new motor? or was the car fine?
Also, what would be "converter?"
Old Jan 31, 2012 | 04:22 PM
These typically don't make much sense. I had my buddy print one of these out for me and half the crap I have had done at the dealer is not on there. I'm not sure what the 4206F is.
Old Jan 31, 2012 | 07:08 PM
godesshunter's Avatar
Voids warranties
Bring it in to your local dealer and ask them to clarify.
Old Jan 31, 2012 | 07:34 PM
jasonrxeight's Avatar
probably replaced catalytic converter under 8yr/100k emission warranty. mine got replaced just a bit over 7k miles.
PCM reprogram being flashing ECU.
Old Jan 31, 2012 | 08:04 PM
right below that, though is Catalytic converter. Done at 15k miles in '06. Same time as 4206F recall.
Old Jan 31, 2012 | 10:27 PM
ken-x8's Avatar
...I was mainly curious about the 4206F recall. I noticed on my report it has a lot of 4206F information. One says rental vehicle, PCM reprogram, another says Cust. Fuel Re (what is that?), and Cust. Vehicle...
4206f is the most famous recall of all. Summer of 2006, at the height of bad press about engine failures. It was a voluntary (for Mazda) emissions recall. They did a vacuum test on the engine to see if the seals were OK. If it flunked, you got a new engine. If it passed, you got an ECU reflash, which corrected most of the ECU related issues about oil injection and flooding. (Flooding fixed by delaying fuel injection until the engine spun a couple of times, plus cutting it off when cranking if floored.)
When you left your car, you got a free rental. They usually did a fillup and a wash before you picked it up.
They made a big thing of "White glove treatment," with bad engines replaced with remanufactured (Ha!) rather than letting the dealers dig into the innards.
Ken
Old Feb 1, 2012 | 12:02 AM
okay so because I got the PCM flash, that means my engine checked out ok?
I'm beginning to understand it more.
Old Feb 1, 2012 | 12:35 AM
maybe. a compression test will tell.
Old Feb 1, 2012 | 04:13 AM
ken-x8's Avatar
Yes. It passed the tests they were doing for 4206f. There should be a TSB posted here saying exactly what they tested.
Ken
Old Feb 1, 2012 | 07:44 AM
Yeah I knew what they tested, didn't know if I passed or not.
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
duworm
Oct 1, 2015 04:57 PM
XianUnix
Sep 29, 2015 03:48 PM
