Misfire in cylinder 2
Old Jan 31, 2012 | 12:47 AM
Brian Henning's Avatar
So I have a misfire in cylinder 2. How should I go about troubleshootings this problem? What steps should I take? I had a plan to switch the cylinder 1 coils with the cylinder 2 coils to see if one or both of them are bad. But if this doesn't work I'm going to need some other ways to figure out the problem before my engine takes a crap
Old Jan 31, 2012 | 02:49 AM
what is this "cylinder" that you speak of?
Old Jan 31, 2012 | 03:25 AM
dozer's Avatar
on his 3rd rx8
replace coils/spark plugs/ and spark plug wires.
Old Jan 31, 2012 | 03:31 AM
Wingznut's Avatar
Go Red Wings!
These are the cause of the majority of misfires. When was the last time these were changed on your car, Brian?
Old Feb 1, 2012 | 08:47 PM
I figured out the problem. I had a bad coil. I replaced it and all is good now
Old Feb 1, 2012 | 11:03 PM
Wingznut's Avatar
Go Red Wings!
You only replaced one? If so, you should replace the other three as preventative maintenance. When one fails, the others are not far behind.
XianUnix
Sep 29, 2015 03:48 PM
Stubbs
Sep 27, 2015 04:06 PM
Tweaked Tay
Sep 25, 2015 07:54 AM
Vedivan1
Sep 18, 2015 12:39 PM
Irvinb16
Sep 11, 2015 10:27 PM
