Multiple Issues!
Old Jan 29, 2012 | 05:11 PM
RX8-Roxy's Avatar
2005 Mazda RX8 - Roxy
Multiple Issues!
I have a series of issues I need help with on my 2005 Mazda RX8.
The Serious-
Engine flooding
Car shutting off
Slow start
The Not so Serious-
Speakers cutting On/Off
No flashing alarm lights
Sunroof makes rubbing noise
Further explanations
Engine Flooding - After driving my car a little hard, the engine begins making a gurgling noise, and is completely sluggish. Low RPM.
Car Shutting Off - After the engine flooding begins, and I bring the car to a halt (stop light - stop sign) it completely dies. It wont start back for at least 30 minutes or has to be jump started.
Slow Start - Occasionally after driving and cutting the car off, then attempting to restart it hesitates or doesn't fire up at all. It sounds like a scratching maybe screeching noise.
Speakers Cutting On/Off - I have the BOSE speaker system in my vehicle, and I've noticed that the driver side speaker will cut in and out often, and sometimes the passenger side.
No Flashing Alarm Lights - This problem occurs only sometimes, I go to set the alarm system on my car via remote, and the lights wont verify that its happened although the horn still does.
Sunroof Making Rubbing Noise - When using the sunroof I press the auto back switch and about 3/4 of the way it starts making a loud rubbing noise. It only started doing this recently.
These are just a few things about the car that bug me and I'd like to have fixed so any and all help would be greatly appreciated. Im 18 and in the U.S Army, so I have money to have it fixed but not alot.
Car Specs
2005 Mazda RX8
Bose Edition
Sunroof
88k miles
Oil change less than 400 miles ago
If you need to know anything more to further diagnose my problem just ask and i'll let you know. I would really appreciate any tips!
Old Jan 29, 2012 | 05:28 PM
RX8Soldier's Avatar
Time for boost...
When was the last time you changed out your plugs/coils?
Do you have the upgraded starter?
Have you had your engine compression verified?
Old Jan 29, 2012 | 05:55 PM
RX8-Roxy's Avatar
I have no clue when the plugs/coils were changed, I purchased the car in October '11
As far as I know the Starter is stock
No I have not had the compression checked.
Old Jan 29, 2012 | 06:14 PM
RX8Soldier's Avatar
Time for boost...
I would recommend changing those. They typically only last 30k miles.
Find out from your dealer if the upgraded starter was installed (or, check the starter for part # N3H1)
But, I'm guessing that your issue is caused by low compression. Only way to verify is to use a rotary-specific tester (dealer/specialist).
Read this thread to get you started on your understanding of the rotary (RENESIS) engine https://www.rx8club.com/new-member-forum-197/new-potential-owners-start-here-202454/
vlad0691's Avatar
Born Again RX8 Fan
Change your coils and plugs asap and see if that works. Also, if you have the original starter, look into that as well. You can check to see which starter it is by looking at the serial number on it. N3Z1 = Original starter. N3H1-A = Upgraded starter.
The worse case scenario is that your engine has lost compression on either one or both rotors and you will need a rebuild or a replacement.
What kind of oil and oil weight do you use? Do you keep up with topping off your oil?
Old Jan 29, 2012 | 06:21 PM
RX8-Roxy's Avatar
Read this thread to get you started on your understanding of the rotary (RENESIS) engine https://www.rx8club.com/showthread.php?t=202454
Alright, I have a local Mazda dealer I can take it to. I have no clue what the starter looks like so i'll have them do that and check for compression. Thanks!
Old Jan 29, 2012 | 06:22 PM
RX8-Roxy's Avatar
Does Mazda cover the starter or engine compression?
Old Jan 29, 2012 | 06:23 PM
RX8Soldier's Avatar
Time for boost...
Mazda no longer covers the starter upgrade, and the compression test will only be cover if it fails the test, and you are under warranty
Old Jan 29, 2012 | 06:39 PM
RX8-Roxy's Avatar
Ok, the starter isn't that expensive regardless, but I did read something on the Mazda site, that they extended all warranties 8 years if the RX8 did have the compression problem.
Old Jan 29, 2012 | 09:37 PM
vlad0691's Avatar
Born Again RX8 Fan
If your car is still under the 100k mi/ 8 year mark then your motor should be covered under warranty.
Old Jan 29, 2012 | 09:55 PM
ZoomieZoom's Avatar
Might as well look towards your CAT too. Not gonna be the root of your problems, but all the unburnt fuel deposits from your frequent flooding has probably degraded it. May have fried your O2 sensors also of course if your O2 sensors were ruined as a reslut of this you should get a CEL code. i would start with compression test and then if that is good then move to ignition and exhaust. You got twelve thousand miles and one year left on your engine warranty. So get your compression checked to rule the motor seals out before you go spending all this money on the rest of it.
Old Jan 30, 2012 | 02:21 AM
Grace_Excel's Avatar
Charles Bundy
-The BOSE Sound System has a self-adjusting feature that allows the volume of the radio to adjust according to the noise outside of the car. Try to disable this feature by turning the AudioPilot 'off' and see if that solves your loss-of-volume problem.
-The lights when you engage/disengage the car alarm will not flash if either hood or trunk lid is open. Make sure both are closed.
-Sunroof noise have been discussed here as well. Grease up those rollers/glides... I read the tread for the DIY, but try a search for it.
Old Feb 11, 2012 | 09:01 PM
RX8-Roxy's Avatar
Thanks so much! I think I just have a fried wire on the speaker, but as for the other two that worked perfectly! Thanks!
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
Randolph Alvarez
May 30, 2016 01:08 AM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
tgaffner
Sep 7, 2015 08:49 PM
