engine stalls when revving
Old Jan 20, 2012 | 12:44 PM
are_ex_ate's Avatar
i just had a greddy se exhaust installed on my 04 a/t. after the install i revved it to see what it sounded like. this was all done in "park". i gave it some gas and the needle went anywhere from 4-6 rpm. the engine started to idle real low and in some cases just shuts off and stalls. this isn't the first time it happened. About a few months ago i installed a racing beat intake. I revved the engine and it would idle very low and also stalls.
ps i might want to add, it doesn't matter if it's in park or neutral. it does the same thing. it drives perfectly though. no cel's either.
Old Jan 20, 2012 | 12:55 PM
RXeligion's Avatar
The X is silent
https://www.rx8club.com/showthread.p...ighlight=stall
This is a short read, and should take care of your issue.
Old Jan 20, 2012 | 01:17 PM
are_ex_ate's Avatar
^ well the thing different from him is that he was driving and it stalled. mine performs flawlessly in gear. i redline the automatic and it doesn't stall like what this guy went through. on another note i replaced my battery a couple months after the intake. should i reset the ecu after the exhaust as well?
more info on my car, it has 37000 miles on it. only mods are racing beat intake, bhr coils, and greddy exhaust. replaced spark plugs last month.
Old Jan 20, 2012 | 01:30 PM
Arca_ex's Avatar
BECAUSE RACECAR
Search dude...
Drive the car normally for a couple days so it can relearn fuel trims...
Old Jan 20, 2012 | 03:22 PM
RXeligion's Avatar
The X is silent
^ Bingo. You can also reset your fuel trims manually IAW the link above.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
ladnarf1
Apr 29, 2021 11:53 PM
vapor2
Nov 3, 2020 03:38 PM
poppinparker
Aug 10, 2015 09:20 AM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
