Thermostat O-Ring Question
Old Jan 17, 2012 | 02:04 PM
r-enzyme's Avatar
For the Masses
CO Thermostat O-Ring / Coolant Leak Question
First off, many thanks to RotaryResurrection, JonG316, 9krpmrx8m, Teamrx8, olddragger and others who helped immensely in removing my engine and replacing it with a reman. I've never worked on engines in my life so this was a big undertaking for me. It definitely wasn't easy but with your help I got it done. I finally drove my car again last Thursday & Friday and it's running great.
Now I'm dealing with a coolant leak that seems to be coming from the thermostat housing. Here is my old therm:
Here is my question, does #6 in the diagram (O-ring) correspond with the black rubber piece in my picture? Or is there another ring that sits above the black one? What is misleading is that in the diagram the black ring appears to be on the thermostat, but it is not listed to the right. Am I missing an O-ring?
Any help is much appreciated
Last edited by r-enzyme; Jan 17, 2012 at 05:31 PM. Reason: Added "Coolant Leak" to the title
Old Jan 17, 2012 | 02:18 PM
Silver_Surfer's Avatar
I4NI
Yes, just replace the T-stat. It comes with a new o-ring.
Old Jan 17, 2012 | 03:23 PM
r-enzyme's Avatar
For the Masses
Sorry if I was unclear.
I installed a brand new thermostat with the reman along with a new ring that matches the one in my photograph.
I'm asking if there is another ring besides the one in the picture that I am possibly missing as the diagram I posted seems to show one ring on the therm and then #6 in addition to that.
Old Jan 17, 2012 | 04:03 PM
Mazmart's Avatar
The O ring in the diagram is the only one. It and #6 are the same. Hope that helps.
Paul.
Old Jan 17, 2012 | 04:12 PM
r-enzyme's Avatar
For the Masses
OK thanks. I appreciate it.
I'll have to look elsewhere for the coolant leak...
Old Jan 17, 2012 | 04:20 PM
make sure the seal fits on like the picture and isn't kinked or it can leak
Old Jan 17, 2012 | 04:32 PM
I4NI
Yes
Note the rubber tab on the lower right side of the thermostat in the pic. Theres a grove in the housing that it fits into.
Old Jan 17, 2012 | 04:58 PM
+1 and when in doubt use high temp red RTV
Old Jan 17, 2012 | 05:17 PM
r-enzyme's Avatar
For the Masses
Cool, thanks guys. Upon further review, the leak seems to be coming from here (where I drew the red line):
Between the lower thermostat housing and the block. The lower thermostat housing came already installed on the reman with a new water pump. If I'm not mistaken, this leak is Mazda's fault.
I guess I'll have to remove it and throw some silicone on it.
Old Jan 17, 2012 | 06:13 PM
halimsteven's Avatar
try to get a gasket for it ....
steven
Old Jan 17, 2012 | 06:21 PM
r-enzyme's Avatar
For the Masses
I actually do have that gasket (unused) because it came with the gasket kit that came with the reman. I didn't use it because I assumed they installed it properly. Clearly I was wrong.
Old Jan 17, 2012 | 06:38 PM
olddragger's Avatar
i always used a black silicone gasket stuff on the thermostat housings--one that goes on the block and the cover. I also do the same for the omp mount. I call it prevenitive
Dude is it just the picture or is one of your omp lines not filled with oil?
Congrats on the install---learned a lot didnt ya!
Old Jan 17, 2012 | 07:19 PM
r-enzyme's Avatar
For the Masses
Thanks od. I learned a TON.
The omp line that looks empty is brand new. I had to replace that one because it cracked when I was installing the omp.
Is there some secret to removing the bolt that goes here?:
I've removed all the hoses around it, the thermostat cover and everything else I can remove conveniently. Is there a way to get this out without removing the engine again??
Old Jan 17, 2012 | 10:33 PM
you can barely see it, but it's easy if you can use the extension and felx head..just have to pay attention ont he location..i beleives it's 12mm size..i change change my thermostat housing, so
that's how i did it..
steven
Old Jan 17, 2012 | 10:56 PM
Yes, it can be removed and installed in the car, but be careful working around and/or moving the plastic OMP lines as they can get brittle with age and crack if tweaked too hard. One of the brackets that holds them in place mounts between the housing and the mounting bolt. You have to pull it out of the way to get the housing off so just be careful
Do not use rtv unless you like having an unnecessary mess to clean up later. The OE gasket and clean surfaces should seal fine without it. Mine never leaked.
Old Jan 18, 2012 | 11:58 AM
r-enzyme's Avatar
For the Masses
Well, sure enough, once I got it off, I saw there was no gasket installed.
Another win for Mazda..... Moral of the story is that I should have checked it when I got the reman instead of assuming they installed it properly..... I'm hoping this is my final project before I really get to break in this reman.
Old Jan 18, 2012 | 12:06 PM
I4NI
jeez, lucky it was'nt somthing important!
Old Sep 5, 2014 | 01:21 PM
Enaris's Avatar
Thread resurrection!
...Because this is incredibly misleading in the manual and this thread answered my question perfectly.
POWER OF GOOGLE
That is all.
05rx8mazda
Nov 28, 2015 09:42 AM
NotAPreppie
12
Sep 24, 2015 03:22 PM
Austin22
Sep 23, 2015 04:46 PM
Wurromurro
Sep 20, 2015 05:02 PM
MolsonB
Sep 11, 2015 12:24 PM
