2004 rx8 car stalls when hot in stop and go
Old Jan 16, 2012 | 07:57 PM
tmags's Avatar
FL 2004 rx8 car stalls when hot in stop and go
need help on what are the conditions fo a faulty throttle body its 2004 with 122k miles engine has been replaced . the car stalls when run hot in stop and go. brought into a shop when i revved it up at 7k rpm it started to backfire upon returning to normal idle and then stalling, when the car cooled down it was fine and engine produced no codes. had an occurance last week and now engine is sometimes on. Dealer says its the throttle body need help thanx
Old Jan 16, 2012 | 08:01 PM
RIWWP's Avatar
Typically the conditions needed to diagnose a faulty throttle body include:
A) failing engine compression and/or failing ignition components
B) A dealer that doesn't know any better
The proper resolution is usually replacing either the engine or the ignition, and your throttle body will they work correctly.
Do some searches through Google with "Site:rx8club.com" about throttle bodies. Nearly every single "failure" or replacement I've seen is when a dealer incorrectly says that your low compression or dying ignition issue is a faulty throttle body. I haven't (personally) seen someone report a justified throttle body replacement. They might exist, I'll allow for that, but it's likely not your problem.
Old Jan 16, 2012 | 08:03 PM
RX8Soldier's Avatar
Time for boost...
do you really think it's a faulty throttle body?
Not saying that a faulty TB isn't the issue. Just, don't limit your problems to just that.
Can you give more details? (mileage, mods, maintenance history, etc)
EDIT: RIWWP, you type way to fast!!!
Old Jan 21, 2014 | 09:30 AM
minishe's Avatar
I have a 2004. Same thing was happening to me, except my check engine light was on intermittently. The code said that the SSV was stuck open. I took it to the dealership. They said there were two large vacuum leaks and sealed them. Runs fine now and the check engine light is off.
Old Jan 21, 2014 | 07:38 PM
04Green's Avatar
Moder8
How old are the coils? They could be getting hot and failing.
Also, look at the $100 thread in my sig. There is a cooling mod or two that will help with under hood temps. Would not hurt to check grounds, clean maf and clean ess while under there..
Old Jan 22, 2014 | 08:18 AM
lazyboijetson's Avatar
hello... I have a 2003 manual RX 8 from Japan with a compression problem... I was considering buying a new engine... I wanted to know if a 2004 or later year would fit in my car.... I know it's probably a stupid question but I still wanted to ask.... also I see that Mazda RX 8 starts from 2004 inside the US ... does my car restrict me to buying an engine only in Japan
Old Jan 22, 2014 | 09:39 AM
RIWWP's Avatar
Japan labels the cars 1 model year newer than the US, a 2003 JDM RX-8 is a 2004 USDM RX-8.
You are looking for a 6-port engine though, so you can use any 6-port series1 engine. In the US this was 2004-2005 manual transmissions equipped RX-8s, and all 2006-2008s, regardless of transmission. Japan may be similar, but I don't know the details of when all the series1 6-port was used over there. I suspect it would be any manual transmission from 2003-2007, and probably late automatics, but I don't know the answer to that.
And no, you can't use the 6-port engine from the series2 RX-8 (2009-2011 in the US)
Old Jan 24, 2014 | 08:48 AM
OK thanks a lot.... and you are most certain that it is a 6 port that i need to get for my car... how do you determine that exactly... is there something that i should look for or its something that you just know
Old Jan 24, 2014 | 08:51 AM
RIWWP's Avatar
Read this post in the new owner's thread (link will jump to the right post): https://www.rx8club.com/new-member-f...4/#post4533721
Old Jan 24, 2014 | 05:35 PM
Ok... by that assessment i have a 4 port series 1 engine.... sorry but i did neglect to tell u that i have a 5 speed manual.... and where is the most recommended place or site for buying another engine
Old Jan 24, 2014 | 06:06 PM
RIWWP's Avatar
I honestly don't know, you are probably going to want to check with your regional forums. The only option from the US that might be viable would be Mazmart, but shipping would be a killer.
SUKIEE
Oct 9, 2017 09:41 PM
dweezil22
NE For Sale/Wanted
12
Sep 9, 2015 10:50 AM
Mr.Durden
Aug 12, 2015 02:21 PM
RX7.9
Jul 20, 2015 12:01 PM
dmengel
Jul 18, 2015 09:35 AM
