Help Please (Clutch Blown)
Old Jan 15, 2012 | 05:09 PM
04RYUU's Avatar
04 RYUU
KS Help Please (Clutch Blown)
first off my car is an 04 6 port mt
so the clutch blew up and had to replace it
got the new clutch replaced it and everything was fine tell i started it now it idels funny it pulses from 1500rpm to 2000rpm but soon as i push the clutch in it goes away and idels perfect
was needing some help please tanks guys
Old Jan 15, 2012 | 05:40 PM
wcs's Avatar
wcs
no agenda
Throw out bearing
Old Jan 15, 2012 | 07:28 PM
04RYUU's Avatar
04 RYUU
it came with everything new, clutch disc, throwout bearing and pressure plate. all is new did i maybe install it wrong???
Old Jan 15, 2012 | 07:37 PM
Check the switch at the clutch pedal....
it will cause the idle to Hunt up and down. Usually between normal speed and about 1500rpm...but up and down.
If it is cold it likely would do it at a higher rpm though like yours
Old Jan 15, 2012 | 08:33 PM
04RYUU's Avatar
04 RYUU
thanks i will check this out ok
Old Jan 16, 2012 | 12:15 AM
the neutral switch on your transmission is malfunctioning, the updated part (new part) corrects this "cold weather idle shoots up and down" issue.
or if u wanna be cheap (like me), just drive the car around for maybe a mile or 2 at slow speed, it will "free" the switch and idle will be well again (but if it happens too often u might get a CEL)
Old Jan 16, 2012 | 01:14 AM
04RYUU's Avatar
04 RYUU
Ok guys update;
Just noticed that that back up lights don't come on anymore when put in to reverse and the engine light came on today when warming her up any ideas??
Thank
Old Jan 16, 2012 | 06:13 AM
RIWWP's Avatar
We usually insist on you providing us a CEL code, since it could be anything from "your gas cap is loose" to "your car is on fire". You still need to get the code read.
However, during the clutch replacement the wiring for your neutral switch and reverse switch were either crossed, reconnected improperly, or damaged.
A) The idle hunt is due to the ECU not seeing that you are in neutral and doesn't know what to do with the air and fuel, and is either caused by severely cold weather, a damaged or defective neutral switch, or a disconnected neutral switch.
B) The reverse lights are triggered based on the reverse switch (which also does other stuff)
C) The neutral switch and reverse switch wiring is the white (neutral) and black (reverse) wiring that runs along the top of the transmission and connects into the 4 plugs near the base of the shifter tower. These have to be disconnected to remove the transmission, and are physically compatible with each other allowing for incorrect reconnection. (I did it wrong at first on my clutch replacement)
It's also possible the wiring harness was pinched by the transmission bellhousing and damaged.
Old Jan 16, 2012 | 03:38 PM
Forget about that riwwp! He doesnt know anythinnngggg j/k man haha
Anyway, im willing to bet ur neutral switch, the cel is the netural switch cel too. Cuz after 2 consecutive cycle if he pcm still sees abnormalties with the switch a light will come on. Check the code see if im right :-D (cuz i have the cel too but i just ignore it cuz i know what it does lol)
Old Jan 16, 2012 | 05:12 PM
RX8Soldier's Avatar
Time for boost...
tl;dr
change the title of your thread. Read the forum rules. Imagine everyone that needed help titled their thread "Please Help!". Good luck with the search feature...
Old Jan 16, 2012 | 05:13 PM
RIWWP's Avatar
^ It's actually not hard to imagine. In fact, imagining it takes zero imagination, just some eyeballing.
Old Jan 16, 2012 | 05:17 PM
alnielsen's Avatar
Originally Posted by RX8Soldier
tl;dr
I made a title change to reflect the problem listed in the first post.
04RYUU, when you signed up for membership, you agreed to follow the rules of the site. Review them immediately.
Old Jan 16, 2012 | 06:35 PM
04RYUU's Avatar
04 RYUU
thanks guys for all the help i will check all this info out thanks
off tue and wed will be checkin it out.
theblinkof
Oct 4, 2023 05:24 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
pjwermuth
Sep 28, 2015 11:36 PM
Trekk
12
Sep 25, 2015 03:08 PM
