DRL fog lights
Old Jan 12, 2012 | 08:42 AM
rx8_fun_man's Avatar
Question DRL fog lights
dose any one know how to make the fog lights DRL's or when the brights are turned on that they will stay on?
Old Jan 12, 2012 | 10:52 AM
Wingznut's Avatar
Go Red Wings!
A quick google search for ya...
Old Jan 12, 2012 | 02:26 PM
Grace_Excel's Avatar
Charles Bundy
Utilize the SEARCH option and this forum will be your friend...
Old Jan 12, 2012 | 04:24 PM
Globetrahter's Avatar
Yeah Man, I did the foglight re-wire, its working awesome. I just posted a thread with my lights on and a video
https://www.rx8club.com/series-i-exterior-appearance-body-kits-27/hid-vvme-3k-h11s-installed-%2Apics-vid%2A-227477/
Old Jan 13, 2012 | 12:39 PM
That's sweet! So next question how do you do it and how big of a project is it?
Old Jan 13, 2012 | 01:10 PM
Myardor's Avatar
Once you understand what/how to do it, it will be about a 5 minute job.
What is the rush, if it takes 20-30 minutes so what
https://www.rx8club.com/showthread.php?t=11737.html
Post 24
Under the DIY forum, it is called a fog light rewire.
Make sure you read it and re read it and do it all over again till you can see it in your head
Make sure you have all tools needed:
1. Something to cut the wires with, dikes?
2. Wire connector: your choice on what type to use
3. Screwdriver/s to remove that small black box (to get to its underside) Not sure if I used screwdrivers to open the box or just pushed the push tabs
4. Something to wrap the wires with, Wal-Mart sells that liquid tape (auto dept) and I think is
much better than regular black electrical tape. (shrink wrap is ok but harder to use/find/buy)
5. Wire stripper, depending on what type of wire connector you use. Some wire connectors do not require stripping the wires.
The liquid tape can be used in many other applications, the shrink tape, only in certain sizes.
The black electrical tape will go bad in a few years, esp with hot summers.
I have done mine, fog lamps on anytime I want, with or without low beams, high beams or by themselves
Those Search vatos are useless, all they do is say....,SEARCH little do they know no one will follow what they say. All it does it ups their post count. USELESS
Old Jan 16, 2012 | 04:03 PM
All done!
cliffkemp
Dec 24, 2024 10:48 AM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
xAgyex
Sep 28, 2015 08:54 AM
Evan Gray
Sep 26, 2015 12:30 PM
