after start, wait until idle drops to 1.5K or below?
Old Jan 11, 2012 | 05:08 PM
szjalo's Avatar
A friend told me so, when start the '8, in cold weather the idle will jump over 2k, keep the car idle until it drops to1.5K or below, then shift and drive the car.
This is also what I did all the time.
But still, I can't help to ask if this is really necessary? or what's the specific reason why we do this? If we don't do this, just drive the car around immediately after start, what's the negative effect?
Thanks a lot in advance!
Old Jan 11, 2012 | 05:16 PM
Tamas's Avatar
Registered Lunatic
I just start the engine and drive without waiting. But it doesn't get very cold around here...
Old Jan 11, 2012 | 05:38 PM
sjschutz's Avatar
Big Poppa Steve
Ugh. Search!
You can drive the car right after you start it if you're in a hurry, just keep the RPMs low (below 4K or so).
Old Jan 11, 2012 | 05:51 PM
jasonrxeight's Avatar
till it drops below 1.5k is good. I at least let it idle 1 min if I want to go in a hurry normally I wait till water temp needle starts to move .
with rx8's little torque, you have to work the rpm to get it going, and I just dont want to put stress on a stone cold engine.
Old Jan 11, 2012 | 07:24 PM
If it is cold you should wait till the idle drops and it warms up a bit...you wouldn't believe how high the oil pressure is at Freezing with 5-30 oil........Let it warm up till the idle drops and the oil pressure is down to a more normal level
Old Jan 11, 2012 | 07:27 PM
ShinkaEvo's Avatar
Triangular Bee Hive
^+1
Especially when rotary engine is much more sensitive to temp compare to piston engine.
Old Jan 11, 2012 | 10:28 PM
monchie's Avatar
I HATE SPEEDBUMPS!
I just turn the ignition key and wait a few seconds, then i go...goodbye.
Old Jan 12, 2012 | 01:51 PM
xexok's Avatar
Originally Posted by sjschutz
Ugh. Search!
I know the s1's dont get the benefit of the moving redline on the tach as it warms up. For me it caps redline at 5k rpm until it starts to warm up then caps it at 7k and then no cap when its finally warm.
I usually idle at least a minute and then start driving but still keeping the rpm's below 3k and then below 4k when its half warm. Its just personal preference anyway, everyone has their own idea about whats alright to do when an engines cold.
Old Jan 12, 2012 | 02:23 PM
Silver_Surfer's Avatar
I4NI
for me also
Old Jan 13, 2012 | 05:41 PM
04RX8man's Avatar
Rotary Powered Countryboy
It's a good idea to let EVERY car warm up some before just taking off...
Jesus Martinez
44
May 6, 2025 08:09 AM
9krpmrx8
Nov 5, 2015 11:45 PM
Redheddude222
Aug 24, 2015 09:14 AM
dbarber
Jul 25, 2015 01:34 PM
