Tein S
Old Dec 23, 2011 | 07:27 PM
kondypl's Avatar
Rotary Fanatic
Tein S
I got my car "lowered" on Tein S springs and I'm very frustrated. I dont if its just me expecting a bigger drop or the guy that put it on for me wrong. The mechanic that lowered the car is and old school guy and I didnt watch him putting them on so I'm not sure if he missed something. There was no preloading done on the front yet because I didnt know something like that exists. I will do it after holidays. I researched on-line they will settle after a week but how big difference that will make , other guy that had tein s on his rx8 told me it took him 2 months to settle and drop nicely... I dont know what should I do??? I dont wanna go to the guy and throw him fit for something thats maybe not his fault. Here's some pictures right after it was done:
Old Dec 23, 2011 | 07:44 PM
Chadwisk's Avatar
Moar Low!
It should only take a week or so for your springs to settle. The most you can do is wait now.
Old Dec 23, 2011 | 07:52 PM
Silver_Surfer's Avatar
I4NI
Go hit some speed bumps., rough roads this weekend.
Old Dec 23, 2011 | 08:11 PM
kondypl's Avatar
Rotary Fanatic
what about preloading? Should I do it now or just leave it and wait...?
Old Dec 24, 2011 | 02:44 AM
RX8Soldier's Avatar
Time for boost...
those are not preloaded. Sometimes, you can wait for them to settle. But, I don't think it will help in your situation.
Bring it back to the mech. No need to throw a hissy fit! Just explain the situation.
Old Dec 24, 2011 | 03:50 PM
monchie's Avatar
I HATE SPEEDBUMPS!
It will settle...just wait for it...if you could wait that long...lol
Old Dec 25, 2011 | 03:54 PM
kondypl's Avatar
Rotary Fanatic
Yes I will go back Tuesday and will do preloading. You can only preload fronts tho right?? I read about it , loosen bolts two bolts and cruise and wait 30 min , thats right?
Old Dec 25, 2011 | 04:19 PM
yomomspimp06's Avatar
El Jefe
https://www.rx8club.com/showthread.p...hlight=preload
Old Dec 25, 2011 | 05:22 PM
lordagrabah's Avatar
Sorry for the big pic but S-techs on stock shocks should look like this. Mine were like yours until I pre-loaded front and rear.
Old Dec 25, 2011 | 08:54 PM
kondypl's Avatar
Rotary Fanatic
^ drop like that would definitely satisfy me , how and if you even can preload rear springs?
Old Dec 25, 2011 | 09:57 PM
RX8Soldier's Avatar
Time for boost...
Originally Posted by yomomspimp06
Old Dec 26, 2011 | 12:04 AM
kondypl's Avatar
Rotary Fanatic
"Here is the rear, should be the bolt on the left and right side of the spring and the one on the bottom left of the spring also.
http://picasaweb.google.com/quatacke...93629865990866"
^ Thats everything there is about rear..... Im not sure which bolts he's talking about , especially the bottom one, but then on the other side I found that you cant preload rear , thats why im asking , no reason to get mad.
Old Dec 26, 2011 | 04:57 PM
kondypl's Avatar
Rotary Fanatic
Originally Posted by brilliantblackrx8
...quick question. Did the installer put these in backwards? Which ones are in the front and in the rear as far as size?
Im not sure , I'll go to him tmrw to help me do the preload and I'll ask him , how is it supposed to be?
Old Dec 26, 2011 | 07:55 PM
monchie's Avatar
I HATE SPEEDBUMPS!
Is your car red or white? The one's on the picasaweb is white.
Old Dec 26, 2011 | 08:43 PM
kondypl's Avatar
Rotary Fanatic
My car is red. I will go , do preload with the mechanic and we'll see hows going to look after that.
Old Dec 31, 2011 | 04:02 PM
kondypl's Avatar
Rotary Fanatic
IL
Ok so its been around week now since I put the springs and I did prelaod on fronts and rear today. This is the drop so far , we'll see if its gonna go even bit lower with time.
REAR:
Front:
Old Jan 2, 2012 | 10:10 PM
whiterx8man's Avatar
Lewisville, TX
preloading springs
I took someone's advice here about preloading. raise the car up, put it on jack stands and then place your floor jack under the suspension and jack it up. Do it slowly until the suspension is all the way up.
Old Jan 3, 2012 | 03:53 PM
kondypl's Avatar
Rotary Fanatic
Front looks all good and even , Im satisfy but the rear looks uneven.... rear passengers side is a bit higher then rear drivers side... Do you think its going to even out with time or do I have to do something about it...??
^ Front looks even and low enough... but rear
Passengers Side
Drivers side (I believe its lower)
Any suggestions???
Old Jan 3, 2012 | 04:31 PM
it could also be where you are parked. my rear sits a little higher if I'm on a slight down slope.
Old Jan 3, 2012 | 07:13 PM
kondypl's Avatar
Rotary Fanatic
I did rear preload once more and also I left the side that seems to be higher on a 2 pieces of wood so its little bit more tucked after an hour of sitting its still the same , at least 1 finger gap difference :/
Old Jan 11, 2012 | 05:45 PM
I4NI
How I preloaded mine was to fill my tank, put my car on drive up ramps(dont drive up) and added weight to my cars trunk and interior before adjusting linkages.
Old Jan 12, 2012 | 08:58 PM
kondypl's Avatar
Rotary Fanatic
It did settle in but driver's side rear is bit higher , I would say maybe around 1,5cm.... We'll see if its going to settle in by its self , if not I'll try to do something about it , buts its going to be spring....
slllygrl10
23
Sep 16, 2016 06:29 PM
beastman_5
Aug 30, 2015 10:22 AM
Billy04RX8
Nov 29, 2004 01:33 PM
DOMINION
Jul 30, 2004 05:26 AM
VividRacing.com
10
Apr 13, 2004 02:12 PM
