Eml was on, but now odd starting behaviour
Old Nov 25, 2011 | 06:23 AM
Lareon's Avatar
while driving the other day the eml came on (didnt flash) while i was on my way home. i pulled up and had to go to work, when i got home i gave everything a cursory look and noticed the petrol cap wasnt on fully so did this up and thought i'd reset the engine management code and see if i could bring it up again and to make sure this was it
(i dont have an obd2 reader but one is on its way)
disconnecting the battery for a few mins and putting it back on reset the code, i then drove to my partners house all was fine, when i got there (the car had warmed up fully) i turned off the engine. 5 mins later when i was leaving her house, the car as i started it instantly cut out. it did this 2 or 3 times until it would stay on. it then on any input of revs would drop and die.
after trying a few times with the revs i managed to get it to drive off and got home without it cutting out. (the eml didnt come on again)
as a side not after disconnecting the battery to reset that first code i turned the car on fully, then pumped the brakes 20 times and turned the wheel i didnt turn the car off after this but drove off ( i dont know if this would have an effect)
any ideas if that could be the problem or if there's anything i should be looking out for. i havent had time to even start it until this weekend.
one other note it was dark and i put the interior light on, whenever the revs would drop and die the light would flicker and dim
Old Nov 25, 2011 | 10:46 AM
Lareon's Avatar
one extra thing
coils and ht leads are brand new 1000 miles ago, the plugs were fine when i changed the coils
Old Nov 25, 2011 | 11:07 AM
Easy_E1's Avatar
Might want to check your battery connections. And alternator output.
Panthersn
Jul 13, 2021 06:30 AM
harithac
Aug 26, 2015 09:24 AM
madrotor
Jul 26, 2015 12:06 PM
nnsoch1776
Jul 22, 2015 04:16 PM
