Transmission fluid in radiator water
Old Nov 23, 2011 | 07:02 AM
Adelante's Avatar
Can anyone shed some info please....
I'm experiencing transmission fluid not heavily in the overflow bottle with some very light brown thick residue when i drain the radiator ..... i have the 04 4spd Auto Rx8 the car starts and runs normal even the gears change's smoothly
So what can be the cause of that???
Old Nov 23, 2011 | 07:10 AM
bse50's Avatar
#50
Are you sure it isn't engine oil or gas?
Old Nov 29, 2011 | 12:49 PM
Adelante's Avatar
i believe it to be transmission fluid.... the dip stick of the transmission has the residue and water on it.... but is there a way to drain the tran fluid....dont know if there is a crack in the radiator that caused it where the fluid passes through
Old Nov 29, 2011 | 03:09 PM
vlad0691's Avatar
Born Again RX8 Fan
Unless the automatic transmission cooler is internal and is located in your radiator ( which I doubt), you shouldn't have tranny fluid in your coolant. Just a guess, I don't know much about the automatic 8's.
Old Nov 29, 2011 | 03:13 PM
TX
Well then why respond at all then? The cooler is built into the stock radiator. It is actually pretty common for manufacturers to cool transmission fluid this way.
Old Nov 29, 2011 | 03:16 PM
vlad0691's Avatar
Born Again RX8 Fan
I just wasn't sure if the automatics had it like that... Cause that could explain his issue.
Old Nov 29, 2011 | 03:17 PM
Adelante, why did you start a duplicate thread? I already answered this in your other thread.
Old Nov 30, 2011 | 07:03 AM
Adelante's Avatar
this all happened when i was on the freeway in 2nd gear @5500rpm when i noticed smoke coming from under the car midway to the back (Fluid splashing on the exhaust pipe) so i pulled over to the emergency lane and saw a trail of fluid on the road it was not drops but more squirted or sprayed line (under pressure i guess) under the engine bay and inside had fluid.....so did it come from a hose or the radiator haven't seen any leaks or drips of fluid since then.. the car has been parked up since then also
The radiator is a new replacement (Spectra) that i ordered from carpartswholesale.com i got 2 years warranty on it so i will have to send it back.... is there a way to drain the system cause even the transmission will have water in it as well...
Old Dec 2, 2011 | 05:17 PM
Adelante's Avatar
I know to drain the radiator...it just the tranny fluid (AUTOMATIC) it as the oil pan... i didnt not get a manual when i bought my car and the one i downloaded does not have anything explaining that.....
Old Dec 2, 2011 | 05:26 PM
TX
Originally Posted by Adelante
I know to drain the radiator...it just the tranny fluid i didnt not get a manual when i bought my car and the one i downloaded does not have anything explaining that.....
You are thinking owners manual, he is talking about the factory service manual.
Here:
http://foxed.ca/rx7manual/2003mazdarx8/
But maybe you are in over your head and should take it to the dealer.
theblinkof
Oct 4, 2023 05:24 PM
airlive
Jun 28, 2020 07:46 AM
XianUnix
Sep 29, 2015 03:48 PM
