problem with temperature
Old Nov 20, 2011 | 04:14 PM
JoJe san's Avatar
friends,
i have a problem of hi temperature, with my rotary, function 20 minutes or more and throw water,, why??? can you help, and not have thermostat,,
Old Nov 20, 2011 | 04:26 PM
paimon.soror's Avatar
Originally Posted by JoJe san
friends,
not sure we can really understand your question. Are you saying that the car leaks coolant after about 20 mins of driving? Also what do you mean by "not have thermostat" ... are you permanently running an open loop or something?
Old Nov 20, 2011 | 04:42 PM
wcs's Avatar
wcs
no agenda
Hey Paimon this comment confuses me.
Could you elaborate a bit please.
Are you suggesting that Engine temperature can force the ecu in to open loop?
I'm confused ... no curious on what running in Open Loop has to do with the OP problem.
Can you help me out here, thanks man.
Old Nov 20, 2011 | 05:03 PM
I was confused on what he meant by "not have thermostat". I was thinking maybe he had somehow bypassed the thermostat so the car would always run like the thermostat was open.
Old Nov 20, 2011 | 05:14 PM
ken-x8's Avatar
Not have thermostat" sounds to me like the thermostat has been removed. Years ago people used to do that in hot weather.
JoJe - put the thermostat back. If you took it out because of an overheating problem, replace it with a new one. Then look for things like a blocked radiator, water pump belt slipping, etc.
If you can describe where the coolant is coming from, that would help.
Ken
Old Nov 21, 2011 | 03:03 AM
JoJe san's Avatar
Ken
you understanding, i don't speak English good sorry,, have flow in the radiator and fan function good, next don't start again.. and have this code: cylinder 2 misfire detected,,and after that heats.
Old Nov 21, 2011 | 03:04 AM
JoJe san's Avatar
yes it is
Old Nov 21, 2011 | 08:07 AM
Wingznut's Avatar
Go Red Wings!
If we are understanding you correctly, and you are running without a thermostat... Ken is right. You need to install it. The restriction that it provides is necessary for the cooling system to function properly.
Old Nov 21, 2011 | 08:28 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
And.....................you have a bad coil or coils.............since you have a misfire code. The misfire code could be plugs or wires, but I would bet coil(s).
How many miles on the car and give us the maintenance history.
Get a thermostat like everyone else says! Also, once again...................where is coolant coming from?
Old Nov 21, 2011 | 10:10 AM
Wrong subforum.
Old Nov 21, 2011 | 02:38 PM
JoJe san's Avatar
ok, yes i do,
Old Nov 21, 2011 | 03:13 PM
JoJe san's Avatar
have 126 miles,, OK change the coils,, the coolant is peak -32 to 230df,,, i get thermostat new.. excellent help
Old Nov 21, 2011 | 03:16 PM
JoJe san's Avatar
who speaks Spanish
Old Nov 21, 2011 | 04:03 PM
Try posting the in the Latin America regional forums. There are many here who speak Spanish. I speak a little Spanish, but not well enough to help you diagnose a problem
Old Nov 21, 2011 | 04:42 PM
xexok's Avatar
joje uso traductor Google y que pueden ayudarle a comunicarse mejor ?
http://translate.google.com/#es|en|
Old Nov 21, 2011 | 05:05 PM
JoJe san's Avatar
ya se amigo pero no se traduce bien y casi no me entienden,, gracias
Old Nov 21, 2011 | 05:07 PM
JoJe san's Avatar
okey friend thanks...
Old Nov 21, 2011 | 05:11 PM
TX
No problemo man. Here you go in case you cannot locate it.
https://www.rx8club.com/latin-america-139/
Old Nov 21, 2011 | 08:03 PM
monchie's Avatar
I HATE SPEEDBUMPS!
I didn't know you speak and understand spanish xexok...lol
Digitz0070
55
Jul 25, 2017 08:40 PM
Zube6115
Sep 30, 2015 12:57 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
