Odd Noise
Old Nov 18, 2011 | 11:39 PM
thisisnotahonda's Avatar
Odd Noise
Only when rpms are between 2500-3500 or somewhere close in that range, it sounds like a belt is slipping (not squeaking), or kind of like a buzzing, something to that nature.....no check engine light, no indication that anything is wrong other than the fact that sometimes I get this weird noise.
It's not consistent. Only seems to happen at lower rpms.
I know I have the secondary air pump sound but that goes away after it warms up, and this sound just started recently...
If anything I've mentioned is a tell-tale sign of something, please let me know...
Old Nov 19, 2011 | 07:44 AM
Now it seems to be happening throughout all the RPM ranges, but it doesn't happen in neutral when the engine is revved.....this is driving me crazy. I wish whatever it is would just break so I can figure out what it is.
It's almost like some sort of crackling sound, definitely not just water going through the heater core or some crap like that...
Old Nov 19, 2011 | 08:03 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
Search out a thread by Jon316G and "SSV", maybe the solenoid is chattering? There is other info in that thread that might be of use as well? This is just a pure guess as to what it may be, since you are convinced it's not MIAC.
Probably need to get in there and isolate where the noise is coming from.
Old Nov 19, 2011 | 08:04 AM
wcs's Avatar
wcs
no agenda
Secondary air pump only operates on startup until the engine is warm.
It's purpose is to reduce emissions.
It adds air to the exhaust to help bring the catalytic converter up to temperature faster.
Old Nov 19, 2011 | 08:22 AM
I'll do a search, just seems unlikely this is the problem as it only seems to happen under a load, and not around any certain RPM. It's making the noise far before the SSV opens up, and MIAC is usually accompanied by a check engine light.
Old Nov 19, 2011 | 08:31 AM
Joe-the_tattoo_artist's Avatar
Got Ink?
You could try disconnecting some belts to see if any pulleys are loose. Before that though, you should check to see if the belts are at the correct tension and alignment. It may be that they are stretched.
Old Nov 19, 2011 | 08:47 AM
I purchased some new belts for the hell of it(have yet to install), not sure if the current ones are off alignment/tension, they have been the same since I bought the car....
Old Nov 19, 2011 | 08:55 AM
Mazurfer's Avatar
Never known MIAC to throw a CEL.............I understand what you are saying about the SSV, but the thread I mentioned has other possibilities in it as well.
Old Nov 19, 2011 | 10:53 AM
godesshunter's Avatar
Voids warranties
You say it doesn't do it in neutral, how about when you push the clutch in? If it goes away then I would suspect the throw out bearing.
Old Nov 19, 2011 | 10:55 AM
Voids warranties
Assuming its a standard transmission.
Old Nov 19, 2011 | 11:24 AM
Unless you are pushing in the clutch the throwout bearing is just idling along doing nothing
Usually throwout bearing failure results in grinding noises when the clutch is pushed in
Old Nov 19, 2011 | 02:22 PM
Only does it while accelerating, and gets louder the higher rpms you go. In neutral with the clutch in or out, does nothing.
Old Nov 19, 2011 | 03:49 PM
xexok's Avatar
If you have a camera handy or can borrow one that should help people. A belt slipping sound to you could be another sound to another ear.
Old Nov 21, 2011 | 08:17 PM
monchie's Avatar
I HATE SPEEDBUMPS!
A sound video can help diagnose the problem of the op, but sometimes its not that easy to tell from a video itself, just sayin'.
Old Nov 23, 2011 | 03:01 AM
I'll try to get a sound clip together, all I can say for sure now is that it doesn't happen in neutral even when you rev the engine all the way to 9k.
Also the sound increases in frequency and volume the higher RPM you go while in gear, and it seems to be relative to RPM and not speed.
I've read about a dozen MIAC threads, what seems to be different about my problem is that it ONLY happens when the car is under load, and in all RPM ranges.
And it's really odd that it just started happening after 91k miles....
It does however seem to be coming from behind the glove box.
Mane
Nov 20, 2015 12:16 PM
nowakm99
Oct 9, 2015 07:10 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
Tsurugi
Sep 7, 2015 08:27 PM
