Not my day
Old Nov 15, 2011 | 05:32 PM
K1NeT1C USMC's Avatar
Not my day
Just got off work. Happy to get In the 8 and drive home. But what do I see when I turn the car on Check engine light . And Mazda is closed right now. Hope nothing too bad
Old Nov 15, 2011 | 05:34 PM
Autozone, Advance Auto Parts, and O'reilly's FTW.
Old Nov 15, 2011 | 05:38 PM
yup, most of those auto part stores will pull the code for free.
Old Nov 15, 2011 | 06:02 PM
Went to autozone it was p0455
Old Nov 15, 2011 | 06:16 PM
Arca_ex's Avatar
BECAUSE RACECAR
lol could be way worse man.
See if your gas cap is tight, it might be leaking.
Old Nov 15, 2011 | 06:42 PM
Renesis555's Avatar
lol definitely not a big issue. Like Arca said, check your gas cap. maybe you didn't tighten it enough, which is surprisingly a very common problem. I had this problem too, and fortunately all I needed was a new gas cap.
Old Nov 16, 2011 | 10:54 AM
Talked to Mazda. They say it's the gas cap an will cost 135 too replace!!!! •___• are they serious !
Old Nov 16, 2011 | 11:17 AM
T-Mar's Avatar
lol, i had the same problem with may car multiple times with this light and i got mine replaced for no where near that at mazda, and I remember thinking it was still a lot, if i recall correctly was like 50 or so and was thinking still charged me like 10 to put on...amh, but ill have to check when i get home to make sure, but that is a lot to put on
Old Nov 16, 2011 | 11:48 AM
Could the bad gas cap be the answer to my bad gas mileage
Old Nov 16, 2011 | 12:01 PM
T-Mar's Avatar
lol, i wish that were the case, but i doubt it although i have been getting better mpg, since not only the fix, but i have cut some of my restrictions in exhaust, basically everything but cat, which could also help, used to get around 16 and been getting 18-20 last 3 fill ups and intake and igniton next to come to see if can bring it up even more. Im going to check bill when i get home to verify bill, but you could just buy cap from them and put it on yourself depending on how much they are charging you for labor.
Old Nov 16, 2011 | 12:02 PM
Arca_ex's Avatar
BECAUSE RACECAR
I'm pretty sure you can buy a generic gas cap from O'Reilly's or something for about 10 bucks. I'd check there first.
Dealership is trying to work you over.
Old Nov 16, 2011 | 12:54 PM
They said they have to clean some gunk out of where the gas goes b/c the bad gas cap let it build up or something like that.
Old Nov 16, 2011 | 02:04 PM
TX
Originally Posted by k1net1c usmc
they said they have to clean some gunk out of where the gas goes b/c the bad gas cap let it build up or something like that.
bs.
Old Nov 16, 2011 | 03:42 PM
Bladecutter's Avatar
Rockie Mountain Newbie
How about you go to your car, pap the gas cap lever, remove your gas cap, and have a look to see if there's any gunk built up.
I'm sure you would have noticed this gunk, if there was any there, when you last filled up your car, but I have no idea if you pay attention to things like this when you're filling up your car.
BC.
Old Nov 16, 2011 | 09:19 PM
monchie's Avatar
I HATE SPEEDBUMPS!
Don't always believe the stealerships, they will rip you off! Just change it yourself, its easy and its much cheaper than the stealerships.
Old Nov 16, 2011 | 11:45 PM
MS Addict's Avatar
Needz moar Mazdaspeed.
I'm glad the dealership I got my 8 from doesn't bs around, at least with me. Then again, I only drop stuff off if it's either broken, and I don't want to/don't have the tools to deal with it, or it's free, haha.
But hopefully it is just the gas cap. Could be a couple other things, but usually it's the gas cap.
jgsnake
General Automotive
Jul 30, 2023 10:26 AM
Danield97
Oct 10, 2015 05:58 PM
Hiroshima_RX
Sep 21, 2015 06:28 PM
Sakebomb Garage
Vendor Classifieds
Sep 6, 2015 03:30 PM
Sakebomb Garage
Sakebomb Garage
Sep 6, 2015 03:29 PM
