Few Issues...not sure where to start first?
Old Nov 14, 2011 | 01:18 PM
jsudz08's Avatar
X08
Ok, I have an '04 manual trans. 51,000 miles.
Been having trouble with a rough idle, more so when clutch isn't pushed in.
Noticed lately while warming up my car in the mornings, it will be idling a little rough, then when I turn the heater on it gets a little worse, and when I turn on rear window defrost, dome light dims slightly, and idling gets even worse.
Sounds like it could be the mounts, from the fan/ac causing it to worsen. But the rear window defrost?? alternator failing? but would that cause the idle to worsen? Was set on changing plugs/coils/wires this weekend (monday/tuesday is my weekend, lovely air force) but since I noticed the dimming and idle change due to the defrost, don't know which direction to go in first?
Old Nov 14, 2011 | 01:28 PM
RX8Soldier's Avatar
Time for boost...
is it cold where you are?
Old Nov 14, 2011 | 01:29 PM
jsudz08's Avatar
X08
The coldest it's been so far was low 30's
Audio Concepts ATL
Sep 26, 2021 01:59 PM
wanted797
Aug 26, 2015 11:24 PM
harithac
Aug 26, 2015 09:24 AM
poppinparker
Aug 10, 2015 09:20 AM
T_Mags
Jul 24, 2015 11:29 AM
