Series I Do It Yourself Forum Wanna save some coin or time/money in the shop? Read up on Do-It-Yourself custom mods and repairs & post your own here.
DIY: Clean your OMP/MOP injectors
Old Nov 8, 2011 | 06:12 PM
Hesselrode's Avatar
US Navy Rotary Enthusiast
I read 8 pages of a 28 page thread today concerning this issue. Since I already had my engine out, I did this to prevent damage to a new engine. I am also doing the SOHN adapter and using 2 stroke with my new engine. That thread enlightened me to how important clean oil is needed to lubricate/cool the seals in the Renesis engine. Hope this saves other people over $200 like it did me. I will be saving $144 on the OMP/MOP lines and hope this saves you money as well.
1.)Get yourself some degreaser, any will probably do, but I used the purple stuff full strength.
2.)Find some hose or something that fits the end of the oil injectors. I used a syringe that was used in making jello shots on Bourbon Street, worked absolutely fantastic. If nothing comes out just fill the top of the injector full of degreaser and allow to sit, Try again, until it comes unclogged. It will just be patient.
3.)Let sit for about five minutes and repeat, several times, until liquid comes out clear.
4.)Now do the same with water, to rinse any unwanted degreaser out of the injector.
5.)Now do the same with air to remover any water that may corrode the inside of the injector.
The picture shows what the stream should look like coming out of the OMP/MOP injector
http://youtu.be/4hC2JxeBEjw
I am working on doing the OMP/MOP lines and will have this done probably tomorrow.
Attached Thumbnails DIY: Clean your OMP/MOP injectors-photo.jpg
Old Nov 8, 2011 | 06:50 PM
laythor's Avatar
I zoom therefore I am.
nice video, but i'm sure whomever actually uses that kitchen is going to want to kill you if they see it
as far as the lines go, seems most people replace them, but at 40 bucks a pop that seems pricey for a DIY.
Old Nov 8, 2011 | 07:36 PM
Hesselrode's Avatar
The DIY isn't 40 dollars a pop. I am unsure where you got that from. This DIY was absolutely free. The injectors on atkins rotary website is $65 a piece and all four lines together were $171 for the set.
Old Nov 8, 2011 | 09:43 PM
shadycrew31's Avatar
WENTGERMAN
interesting, why didn't you use carb cleaner?
Old Nov 8, 2011 | 11:18 PM
laythor's Avatar
the lines are about 40 bucks a piece, not the DIY you posted
Old Nov 9, 2011 | 07:47 AM
Hesselrode's Avatar
Oh, you just said it seems pricey for a DIY. I am not sure what that means.
Old Nov 9, 2011 | 10:10 AM
Did you do the vac test on them when you were done?
You have to be careful blowing compressed air into the valves...they tend to lock stuck open and won't hold vac properly. Make sure you blow the air into them in the closed position to re-set the ball
Old Nov 9, 2011 | 10:29 AM
Going through all the trouble and then not properly testing them seems stupid IMO. Okay, they are clean, but do they function properly? It's not a lot of money to have the peace of mind of knowing they are new. Especially if this is all going back into a new motor.
Old Nov 9, 2011 | 10:34 AM
Chris's Avatar
Turbo Member
this is a great point.
Old Nov 9, 2011 | 10:35 AM
lta_ds_fs7's Avatar
I need to vacuum test my lines...*sigh*
Old Nov 9, 2011 | 10:38 AM
TX
The lines don't need testing, it's the injectors themselves. The lines just get dry-rotted over time and possibly clogged. I just replaced all of it for the peace of mind. It's only $300.00 or so.
Old Nov 9, 2011 | 10:44 AM
Chris's Avatar
Turbo Member
I need to replace my lines. For some reason... I am not using any premix
I have replaced injectors (tested before replacing) and still no use.
I am leaning towards replacing the OMP all together
lta_ds_fs7's Avatar
Really?...I couldn't find anything that cheap...Where did you order from?
Old Nov 9, 2011 | 10:52 AM
WENTGERMAN
$1500 later
Old Nov 9, 2011 | 10:54 AM
Chris's Avatar
Turbo Member
really... wow, havent looked into the costs yet, but damn
Old Nov 9, 2011 | 10:56 AM
I paid $50.00 per injector at my local Mazda dealer and I think I paid $35.00 per line as well. It wasn't more than $350.00 I don't think.
TX
You can get an OMP for $300.00 or so used.
Old Nov 9, 2011 | 10:57 AM
lta_ds_fs7's Avatar
I think he was attempting to be an ***...lol
Old Nov 9, 2011 | 11:00 AM
WENTGERMAN
No seriously brand new that little hooker costs as much as a used engine, or a really fun night in Vegas.
I think its $1584 or some ****.
When I had my engine off I was throwing that thing around like it was a rag doll. I would have locked it in a safe if I knew how much it costs.
lta_ds_fs7's Avatar
Hmmm...I may just replace them with RB steel, braided lines...not too much more.
Old Nov 9, 2011 | 11:02 AM
WENTGERMAN
Only problem with them is you can't see the lines, it being one of the biggest life lines in the car I like to check on their condition often.
Old Nov 9, 2011 | 11:03 AM
TX
You are confusing lines, the RB lines feed the oil coolers, not the injectors. But I have those in hand to go on Hoss-05's car and they are good pieces, but the price is kind of ridiculous.
Old Nov 9, 2011 | 11:06 AM
WENTGERMAN
Someone somewhere was talking about getting a banjo fitting at the end of a braided line. I thought it was RB or mazdatrix.
Old Nov 9, 2011 | 11:07 AM
lta_ds_fs7's Avatar
I thought they had a kit that replaces ALL of the lines :/
Old Nov 9, 2011 | 11:09 AM
Considering how many bends they have to make I don't see SS lines being a viable replacement option. I considered doing something different with them but I think the factory lines are just fine for 100,000 miles or so.
