Could malfuctioning SSV create chatter noise??
Old Nov 5, 2011 | 06:56 PM
DHPrx8's Avatar
Could a malfunctioning SSV create chatter at higher revs 4k-5K if it is not opening correctly - ie enough - or is sticking AND create loss of power at the same time?
Sounds like a simple questions and yes I have read and posted.
What metalic part could be chattering when I get to the 4K -5K range?? Is there anything that Opens when the boost is needed? Wondering if maybe it it is trying to open and is getting stuck - or is it just the SSV that turns to provide the right mix?
thanks all.
Old Nov 5, 2011 | 07:27 PM
RX8Soldier's Avatar
Time for boost...
some info here
Old Nov 6, 2011 | 07:42 AM
VOODOO8's Avatar
Hermitage Holdout
thanks all.
If your 100% confident you have localized the noise to the SSV, then please ignore this comment. If not, then another possible source of chatter/clatter noise in the same rough vicinity might be worn bearings inside the alternator.
Mane
Nov 20, 2015 12:16 PM
nowakm99
Oct 9, 2015 07:10 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
Evan Gray
Sep 26, 2015 12:30 PM
