No power to the stereo and display?
Old Oct 22, 2011 | 09:51 AM
andycrx8's Avatar
Angry No power to the stereo and display?
I have just taken the stereo unit out to fit an iPod cable (instructions will follow) and the stereo and display is not working. All the power cables are plugged in and I've removed the iPod cable in case it was that and still nothing.
The hazards switch works.
The sat nav unit and controls work.
Heated seats work.
The Cd changer kicks in when the power cable is connected.
The heater and fan is working.
It seems that all the stereo/air con controls don't work and the display is blank - nothing happens when the car is turned on.
I've checked the fuses and they're ok - any ideas?
This is baffling me!
Old Oct 22, 2011 | 10:20 AM
zoom44's Avatar
here are just a smattering of posts for you to read.
https://www.rx8club.com/showthread.p...=display+blank
https://www.rx8club.com/showthread.p...26#post3921126
Old Oct 25, 2011 | 03:18 PM
ChrisAZGT's Avatar
The faceplate has pulled away from the actual stereo. I just did this repair myself.
The first link mentioned above is the quick and easy way to fix it.
Old Oct 25, 2011 | 10:08 PM
Souljam's Avatar
+1 on the faceplate not being properly hooked up to the radio. Happened to me when I did the heater/ac repair.
Old Aug 12, 2019 | 06:37 PM
Frank Clark's Avatar
I had the same symptoms. No LED display, AC not working, radio not working. Fan worked and hazard lights worked. I had switched out my faceplate and disconnected the radio. After reinstalling most of the functions did not work. What I discovered was that the black cable jack had not been inserted properly. All 4 other white plastic lock-type fasteners had stayed in but the black cable jack (maybe power jack) had come loose. When I inserted it more deeply it stayed in and solved the problem. Every console component now works as it did originally.
wintermuteCF
Mar 30, 2021 10:33 PM
Ravioli
Nov 8, 2012 02:48 PM
Nopstnz8
Jun 3, 2012 04:14 PM
LadyRenesis
Dec 31, 2010 05:03 PM
Romagical
Apr 11, 2009 10:49 AM
