My handling went out?
Old Sep 29, 2011 | 10:06 PM
dakotabooi's Avatar
Ive received this car about 5 days ago and the tires were worn down and the dealership replaced the back two free of charge. the handling was perfect just like everyone described BEFORE he put these tires on, and now the handling is bad, doesn't take turns right and runs over itself when taking a turn hard. making a noise like the weight is all going towards the front tire you turning to. any suggestions? or similar problems? my system light is on that looks like this: (!) and flashes but the previous owner(not the dealership) told me that that was no problem and it flashed all of the time and its cuz he had a mod done too it and then taken off but, so im pretty sure thats irrelevant because it handled like a champ before they messed with the tires today, it was completely noticable.
Old Sep 29, 2011 | 10:21 PM
RX8Soldier's Avatar
Time for boost...
1. Delete all the other threads you just started. Leave this one.
2. Are the rims/ tires aftermarket?
3. Did the dealer balance the tires? Proper tire pressure? Do the front tires have good tread left?
Old Sep 29, 2011 | 10:31 PM
dakotabooi's Avatar
nope stock rims and tires and all 4 tires are the exact same tires and the back are brand new and the front have over 80% left on them.
Old Sep 29, 2011 | 10:53 PM
RX8Soldier's Avatar
Time for boost...
is there any wobble? Make sure that the wheels are torqued to spec
Old Sep 29, 2011 | 11:15 PM
dakotabooi's Avatar
nope no speed wobbles or anything when i turn it used to be pin point but now it like sways back and forth. its very dangorous actually it scares me and when they worked i felt completel safe going 85 down a winding road now i feel safe going 50..
Old Sep 30, 2011 | 12:33 AM
monchie's Avatar
I HATE SPEEDBUMPS!
Did you have an alignment done? Just trying to make sure because you never said it on your post.
Old Sep 30, 2011 | 12:41 AM
ANIBALRX8's Avatar
Cool
You do not need to do alignment, unless the handling is off, but I do agree if you handling is off do an alignment!
Old Sep 30, 2011 | 12:16 PM
dakotabooi's Avatar
im not sure if its an alignment problem though. the handling just way different than it was, i used to be able to take a turn at 80 and now it digs into the front tire while i turn at 55-60. and slows my car down.
Old Sep 30, 2011 | 12:24 PM
fuztupnz's Avatar
Phone Booth'd
Is the ( ! ) light in the left cluster? If so, check all of your tires' air pressure. That's most likely your tpms light blinking. Your are either have a tire or two that are low, or you may have a bad sensor(s).
A low tire or two will drastically effect handling.
The tires themselves could effect handling. Are they all the same brand/model of tire? Mismatched tires will give you mismatched results. Your fronts may be stickier than your rears or vice versa. It could have a drastic impact on handling.
Old Sep 30, 2011 | 01:54 PM
Atilla's Avatar
I am THAT guy
btw, my gas went out. I drove it to work and back all week and now it went out. When i bought it at the dealership it was fine but then they replaced my gas and now its not the same. There's a light by the big "E" on my dashboard thingy...
Any suggestions?
Old Sep 30, 2011 | 05:05 PM
Jake33's Avatar
Dudemanbro
I think the "E" means you have to run %100 Ethanol...the dealership prob put in 93 octane or something.
Old Sep 30, 2011 | 07:44 PM
Tamas's Avatar
Registered Lunatic
Or it could also mean that the Electric motor is activated...
Old Sep 30, 2011 | 09:23 PM
monchie's Avatar
I HATE SPEEDBUMPS!
Any suggestions?
No comment...lol
Old Apr 26, 2012 | 08:15 PM
deadpool's Avatar
Bazinga!
Thread revival!
I'm having the same problem. Replaced just rear tires. Suddenly handling goes to ****. DSC activates on curves I used to be able to take easily at 20-30 mph more than I can take it now. Rear wobble on the freeway. Tires are same size but fronts are at 50% compared to the brand new rears. Different brands, fronts are Potenza RE-01 and rears are off brand (I bought them because I had huge *** nails in my rears and needed tires to get home).
I do NOT feel safe in my car anymore, I used to think this car could handle anything.
If the answer is that my rear tires are ****, I'll happily change them, but I need to be sure before I commit to buying 4 new tires.
Old Apr 26, 2012 | 09:02 PM
JCrane82's Avatar
Trust Me, I'm an Engineer
Move rears to front, repeat test drive.....
Michael Bryant
Oct 12, 2015 03:07 PM
JAYDOH
Sep 24, 2015 01:54 PM
doc.tarzan
Non-Rotary Swaps
Sep 24, 2015 08:32 AM
Hunter of Gunmen
Sep 21, 2015 06:27 PM
