Rubber lining underneath car
Old Aug 30, 2011 | 10:20 PM
Rotary-RX8's Avatar
Girls who drive stick FTW
What exactly is the purpose of that rubber that runs along the sides of the car underneath it ?? When you install the side oem flares youre supposed to cut part of it. I was wondering if its okay to remove the whole thing on both sides
SOmetimes you can see where it was cut to accomodate the flares and it kind of bothers me lol.
Thoughts ?
Old Aug 30, 2011 | 10:25 PM
RX8Soldier's Avatar
Time for boost...
rust protection
Old Aug 30, 2011 | 10:33 PM
Rotary-RX8's Avatar
oh really. So i guess i should just leave it then lol.
Old Aug 30, 2011 | 10:53 PM
Easy_E1's Avatar
If you do remove it, which is only a slight issue.
Issue being. Be sure to fill the holes in the rocker panel that are left when you remove the mounting clips. A rubber plug of some type would work. As long as it's sealed. Otherwise moisture will enter and rust will follow.
Old Aug 30, 2011 | 10:59 PM
Rotary-RX8's Avatar
i was planning on just re-using the clips that are attached to the rubber now. In other words remove rubber with clips then put the clips back on.
Thanks for the advice guys
Old Aug 30, 2011 | 11:18 PM
Easy_E1's Avatar
Might have to colorize the clips. I don't believe they're black.
Old Aug 31, 2011 | 12:40 AM
RXeligion's Avatar
The X is silent
OP, would you mind posting pics with the strips removed? These are eyesores on my '04.
Skyl3r
Dec 2, 2019 04:51 PM
BigMikeATL
May 26, 2016 12:31 AM
MsKingRotary
Jan 28, 2016 12:12 PM
michaelsk8er
Nov 9, 2015 07:06 AM
AussieGray
Jul 16, 2015 03:58 AM
