flickering dome light
Old Aug 25, 2011 | 10:54 PM
dlum125's Avatar
my dome light has been flickering for several months now, and it's really annoying. could it be the connection? or the blub?
if it's the connection... x.x
Old Aug 25, 2011 | 11:58 PM
Figs's Avatar
Auto to manual swapped
Mine flicker when they dim because they're LEDs. Could be the bulb though cheapest thing to try first really
Old Aug 26, 2011 | 03:01 AM
Grace_Excel's Avatar
Charles Bundy
I bet it's the connection, otherwise, if you use LED then it's the bulb like 'Figs' stated... When you replace the bulbs, you have to twist the holder counter-clockwise; sometimes the plastic piece at the base breaks causing it to loose contacts on the cooper connections. I glued mine with Elmer's Glue so it's easy to remove if I have to replace the bulb.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Evan Gray
Sep 26, 2015 12:30 PM
