Super Sensitive Rx8 Alarm
Old Aug 25, 2011 | 06:44 PM
katyeng731's Avatar
I have a 2005 Rx8 that I just bought used. I was told that no work had been done to it that wasn't anything factory-installed so as far as I know it has the original car alarm in it. I have so many problems with the alarm going off all the time! If a loud car or motorcycle drives by it goes off. If a squirril runs across the hood it goes off. If it's storming outside and thunder cracks too loud it goes off. My neighbors have started complaining because it is waking their kids up in the middle of the night a lot... Is it possible to de-sensitize the alarm so that it only goes off when something is actually happening to my car? Or if that isn't possible, is there a way to just turn it off alltogether?
Old Aug 25, 2011 | 06:52 PM
SayNoToPistons's Avatar
Wheels, not rims!!
Most likely the alarm shock sensor upgrade. It is a little device located in the passenger side footwell. If you dont want it, ill take it!! Here is a pic:
Old Aug 25, 2011 | 07:07 PM
jasonrxeight's Avatar
I think there must be a way to adjust sensitivity.
must be under a rubber cover on the device.
Old Aug 25, 2011 | 07:12 PM
assume it's using stock shock sensor, its located underneath/behind the glove box. Look at there, it should be mounted at the brace, it's a little square-ish box that has a little red light on it, when you shake the car, the light turns on. there is a little **** next to it to adjust it's sensitivity. From your "cat runs over hood = alarm goes off" or "nothing happens unless you physically smack the sensor"
how I know? I installed the shock sensor myself.
Old Aug 25, 2011 | 07:16 PM
StealthTL's Avatar
Metatron
Small black box high up on the passenger footwell doorpost, behind a piece of plastic trim. Has a **** on it for sensitivity.
This thread has good pics....
https://www.rx8club.com/series-ii-diy-161/diy-alarm-shock-sensor-upgrade-install-sii-215064/
Old Aug 25, 2011 | 08:10 PM
Wheels, not rims!!
Aw damn. My Hot linked pic didn't work . Apologies.
Old Aug 26, 2011 | 12:13 AM
monchie's Avatar
I HATE SPEEDBUMPS!
Didn't know the oem alarm is adjustable. Thanks for the info.
Old Aug 26, 2011 | 01:55 PM
blackenedwings's Avatar
Life begins @ 30 psi
Yup, I have the same issue, I installed the shock sensor ages ago and its set a bit too sensitive still. My Evo sets off the RX-8 alarm every time I pull into my parking space. My neighbors love that I'm sure.
Old Feb 7, 2012 | 12:42 PM
stelios_pet's Avatar
Smile
https://www.rx8club.com/showthread.php?t=215064
thanks thanks thanks thanks
Old Sep 5, 2012 | 11:27 PM
rx8mrkrl's Avatar
I also have this problem on my 2004, I just got the car recently and it was a repo and doesn't have the original key or remote.
The alarm seems to go off right after I lock it which has only happened 3 times that I know of, it's stored in an apartment parking garage at night so this is a big problem for me.
Will getting this sensitivity upgrade solve this?
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
PotatoCannon
Sep 6, 2015 11:48 AM
RXeckless
Aug 16, 2015 12:52 PM
Belalnabi
Jul 22, 2015 04:50 PM
