Differences in ECU's between 4 port and 6 port?
Old Feb 26, 2004 | 03:25 AM
rx-8club.co.uk's Avatar
Hi all,
Does anyone know if there are any differences in the 4 port and 6 port ECU's?
i.e. are they are completely different unit? do they have the same wiring loom etc.?
Thanks in advance.
Old Feb 27, 2004 | 11:37 PM
Old Feb 29, 2004 | 03:14 AM
Anyone got any ideas?
I would assume that the tune itself would be different between the two engines/ecu's.
But I want to know if the wiring in the unit itself is different etc.
Anyone have access to part numbers?
Old Feb 29, 2004 | 04:59 AM
Mr M's Avatar
Evolution of REvolution
I'll check the part numbers on Monday and get back to you.
Old Feb 29, 2004 | 05:43 AM
Thanks Mr M.
Old Mar 1, 2004 | 01:54 AM
Mr M's Avatar
Checked the parts catalog for Europe, the PCM's for Hi Power and Std Power (or 5spd transmission and 6spd transmission as they are categorized in the catalog) are definitely different.
Old Mar 1, 2004 | 02:50 AM
I suppose it doesn't go as far as the board itself?
I would assume that some of the wiring is slightly different, and the map itself.
Would like to know if the board is different?
Old Mar 1, 2004 | 08:50 AM
JeRKy 8 Owner's Avatar
Stuck in a love triangle
I wonderif the primary port that opens at 3750 RPM on 6speed also opens at 3750 on the automatic
Old Mar 1, 2004 | 04:22 PM
Don't you mean secondaries? Primary ports run all the time. Secondaries open around 3750rpm (on the 4 port engines).
Old Mar 1, 2004 | 09:20 PM
Yesthats what I meant. So Iguess that the keeping RPMs below 3750 manuever for better gas mileage is alsorelevant to the automatic Rx8s too. Forsome reason I just had a feeling that the secondaries opened a littlebit earlier on the automatic since the manual runs much differentlyand has the extra 1500 RPM.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Evan Gray
Nov 24, 2015 01:00 AM
bosstin87
Oct 5, 2015 06:52 AM
Stubbs
Sep 27, 2015 04:06 PM
Evan Gray
Sep 26, 2015 12:30 PM
