tire sign
Old May 12, 2011 | 09:44 AM
sultanofak's Avatar
tire sign
My tire presure sign keeps coming on when ever I'm driving. At first it is off but later comes on. I had them check twice but the repair shot said the presure was fine confused on what needs to be done.
Old May 12, 2011 | 10:08 AM
Spin9k's Avatar
Momentum Keeps Me Going
Check the pressure yourself to be sure, if it's ok according to the door decal, ask yourself... do I have the orginal wheels and tires or have they been swapped out? If they've been changed for new wheels, they likey aren't there anymore, or, someone could have broken/removed the wheel TPMS module while changing a tire, or the battery could have gone (unlikely).
You REALLY go to a repair shop to check your tire pressure..... just wow....
Old May 12, 2011 | 11:17 AM
Agent XY's Avatar
There is a delay at the beginning before it starts reading. I think it is something like 10 minutes. That would be why you don't see it when you start the car up.
Old May 12, 2011 | 11:50 AM
dynamho's Avatar
Try the reset procedure. It's in the owner manual.
If that doesn't work, just put tape (to block the blink) on the gauge or simply ignore it.
I just ignore mine. TPMS is poop for lazy folks anyway.
Old May 12, 2011 | 07:43 PM
DocBeech's Avatar
I drive at Red Line.
The new TPMS sensors have no delay, if my pressure is low the light comes on about 10 seconds after start up. If it goes back off when your driving then your tire pressure is just barely off. The tires heat up as you drive which can push the pressure as high as 5lbs per tire over a cold reading.
Old May 12, 2011 | 11:51 PM
monchie's Avatar
I HATE SPEEDBUMPS!
Might be a defective sensor(s).
Old May 13, 2011 | 12:24 PM
CyberPitz's Avatar
Huge hole is huge
I agree with buying a 2 dollar pressure gauge and checking it yourself to be safe.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
Michael Bryant
Oct 12, 2015 03:07 PM
duworm
Oct 1, 2015 04:57 PM
