Best injector setup for BNR/Greddy turbo setup
Old Mar 27, 2011 | 07:39 PM
USMC_Skip's Avatar
Boosted Marine
I'm in the middle of an engine rebuild and while my engine is out I would like to upgrade my injectors. I am also planning on upgrading to the Walbro fuel pump. Do I just need to change the P2 position or what? I understand some have swapped in blues or uncapped yellows, I would like to get the fuel setup right from the beginning. Thanks in advance.
Old Mar 27, 2011 | 09:28 PM
Brettus's Avatar
Boosted Kiwi
yellow/ blue/ blue is the best .
Next question .....
Old Mar 28, 2011 | 11:51 AM
CompMan's Avatar
iDüber
I also just got my engine rebuilt. while tuning mazdamaniac said my afr's went lean under WOT and was causing detonation.
My fuel pump has 90,000 miles, 20,000 boosted so I figured I am going to get the Walbro fuel pump also.
The only thing I am not sure of is what injectors I should get to obtain the most reliable power.
Old Mar 28, 2011 | 04:43 PM
Rote8's Avatar
Sounds like you may need a few tweaks to the tune, lean is bad.
I always start rich an work towards leaner, it's easier than engine replacement.
Old Mar 28, 2011 | 10:28 PM
USMC_Skip's Avatar
Boosted Marine
Originally Posted by Brettus
yellow/ blue/ yellow is the best .
Next question .....
It would appear that I am now on the hunt for blue injectors, where oh where are these blue injectors my build should be done in roughly 2.5 weeks and I need them
Old Mar 30, 2011 | 05:27 AM
stinksause's Avatar
The Stink w.o The Sause
http://www.discountfuelsystems.com/s...&events=search
Old Mar 30, 2011 | 05:37 PM
USMC_Skip's Avatar
Boosted Marine
I'm not exactly sure if I want a remanufactured one, I'd rather get one straight out of an automatic. Unless I find one on here i'm going to search junkyards I guess
Old Mar 31, 2011 | 11:49 AM
SEANMAC777's Avatar
I have also been wondering about this for a while...
I just received my Greddy Turbo Kit w/ upgraded turbo, and I figure I will need to upgrade the fuel system while I am at it.
I already plan on doing the Walbro pump, but how do I know what size injectors to get?
I see some say you need to get much bigger, like the 650cc injectors from RC Engineering, and then others say just to use the blue 4 ports.
I plan on eventually getting up above 300whp, so are the blue injectors sufficient enough for this?
Thanks, Sean.
Old Mar 31, 2011 | 12:07 PM
pdxhak's Avatar
Official Post Whore
I have P2 Blue 880c and have no issues with getting enough fuel.
Old Mar 31, 2011 | 01:11 PM
stinksause's Avatar
when you are upgrading injectors, it is important to consider what engine management you are using as this plays into injector staging. Personally, I plan on running yellow, blue, blue ... should be enough for 300 - 330 rwhp ... I think that is the optimal set-up if you are using COBB
oh and I DO plan to upgrade the fuel pump
Old Mar 31, 2011 | 10:13 PM
SEANMAC777's Avatar
Ok, and now I have a stupid question. When you say yellow, blue, blue....Where are you putting each? Like yellow in p1? blue in p2??
Old Apr 1, 2011 | 11:59 AM
stinksause's Avatar
primary -> yellow
secondary -> blue
P2 -> blue
Old Apr 1, 2011 | 03:12 PM
USMC_Skip's Avatar
Boosted Marine
Awesome, definitely going to go this route and see what it gets me
Old Apr 2, 2011 | 12:12 PM
Rote8's Avatar
P-1 = Stock red
P-2= Stock Yellow
Aux = 4 port AT Stock Blue
Old Apr 26, 2011 | 10:30 AM
USMC_Skip's Avatar
Boosted Marine
is the following a shitty version of the blues? and at $41 a piece are these going to crap out on me sooner rather than later?
"GB Fuel Injector - Direct OE replacement
2004 Mazda RX-8 Base 2 Cyl 1.3L -- GB MULTI PORT INJECTOR, REMANUFACTURED -- A high quality, direct fit OE replacement multi port injector; Features orifices that provide better fuel atomization, which is beneficial in reducing emissions; With GB's 12-month or 15,000-mile warranty.
Part Number: G5842-12331
Fit Note: Automatic Transmission, OEM# : N3H113250A, N3H313250A
Type: Direct OE replacement
Condition: Remanufactured
Quantity Sold: Sold individually"
Old Apr 26, 2011 | 10:52 AM
MazdaManiac's Avatar
Originally Posted by Rote8
P-1 = Stock red
P-2= Stock Yellow
This is wrong. Always put the largest injectors in the P2 position. The secondary (what you just called "aux") injectors are behind a valve and aren't always available for supplemental fueling. Additionally, they are partially tapered out of the equation relatively early in the RPM band.
The "green" injectors from the SII are the best choice for the primary 1.
Old Apr 26, 2011 | 12:58 PM
stinksause's Avatar
how much do the greens flow? they are interchangeable?
Old Apr 26, 2011 | 01:20 PM
They are a drop-in replacement and flow about 400cc, but their spray pattern is significantly improved over any of the previous designs. The result is much better economy and injected volume control and precision.
Old May 4, 2011 | 11:14 PM
CompMan's Avatar
iDüber
P-1 = Series II
P-2= 4 port AT Stock Blue
Should that get me around 330whp?
Old May 17, 2011 | 09:48 AM
Highway8's Avatar
Registered RX8 Nut
I am trying to find the Green injectors from a Series II but I am not having any luck online. Anyone have a part number? I might need to call a mazda parts department but without knowing which position the green injectors are in, I am not sure they will be able to help me.
When I look them up on line they say, Housing or Manifold.
Also, denso shows the same part # for 2009 as 2004-2008 but is not showing anything for 2010. So did they switch to green injectors in 2010?
Old May 17, 2011 | 09:50 AM
Highway8's Avatar
Registered RX8 Nut
P-1 = Series II
Might want to go with modded blues or yellows instead of stock blue.
Old May 17, 2011 | 09:57 AM
Highway8's Avatar
Registered RX8 Nut
The GB fuel injectors are "remanufactored" which means they are stock denso injectors that have been cleaned and maybe flow test. There is usually a core charge. Rockauto.com has the best price that I could find.
Old Jun 22, 2011 | 01:19 AM
hoss -05's Avatar
Lucky #33
Thanks go out to Ash.
2 x N3R1-13-250 Green
2 x N3R2-13-250 Red
Old Jun 23, 2011 | 12:04 PM
RotaryMachineRx's Avatar
SPOOLN8
I'm hoping to hit 350whp eventually, my understanding was always
P1 - Green
Secondary - Blue
P2 - Blue
would be sufficient for that goal.
Didn't realize they meant modified blue for the secondary though?
Old Jun 23, 2011 | 12:19 PM
Highway8's Avatar
Registered RX8 Nut
P1 - Green
Secondary - Blue
P2 - Blue
Modifed blues or yellows will both work. Stock blues might work, but for the small extra cost, its just best to modify them. For a long while many people were using stock p1's and secondaries and only upgrading to the modified blues or yellows for the p2 position. However with that setup the injectors were reaching their limits.
I will be putting some modied yellows and pink denso injectors up for sale. The pink denso injectors were flow tested and flow 10% less then modified yellows.
Hunterkelley24
Jun 14, 2022 08:32 AM
hufflepuff
May 30, 2016 10:45 AM
MolecularConcept
11
Sep 29, 2015 09:21 PM
Jb4ker96
Sep 27, 2015 10:06 PM
Learners_Permit
Sep 27, 2015 07:38 PM
