aftermarket rotors/modified rotors
Old Feb 14, 2004 | 11:46 PM
MadThrillzChill's Avatar
Bad ass muthrfukr schl 05
Is there any plans, or is even possible to manufacture after market rotors...like it is pistons. Although the compression on the renesis allows for boost i would still rather be on the safe side and run a lower compression. If not is there a way to "cut " out the dish in the regular rotor and "weld" in new dishes?????????????
Old Feb 15, 2004 | 11:50 AM
rotarygod's Avatar
There were shops in the past that did lower the compression ratio by dishing them out. Hayes Rotary used to make compression ratios as low as 7.5:1. I'm not sure of the casting thickness of the new rotors though. The older ones were much heavier whcih implies more material is available for machine away. It can be done though. I've never seen anyone else manufacture new rotors.
Old Feb 16, 2004 | 12:49 AM
Omicron's Avatar
I think there's a rotary shop up in Alberta near CanZoomer that's doing just this. Remachining the rotors to lower the compression ratios (to make it more suitable for FI) and installing ceraminc apex seals.
Old Feb 16, 2004 | 12:41 PM
Smile
thank you for the information..... that was my first post
Old Feb 18, 2004 | 12:26 AM
rxturbo's Avatar
Racing Beat will do this mod for you but the problem would be that Mazda have taken more metal out of the rotor guts now to save weight and it would end up very thin. We are looking into putting rx8 rotor gears into Ser4 turbo rotors so you still have the nice new high reving gears but the 8:4 comp rotors
Old Feb 18, 2004 | 12:48 AM
rotarygod's Avatar
That won't work. The S4 rotors do not have the blow by seal that the Renesis rotors have. Changing the rotor gears won't affect this. BTW: Their compression ratio is 8.5:1.
Old Feb 20, 2004 | 09:58 PM
rxturbo's Avatar
The blow-by seal is only to stop the intake and the exhaust from overlaping when the rotor is around TDC, but its something that could be machined into the rotor and besides i guess i was mainly thinking if these rotor were in older motors but with the RX8 shaft gears and stat gears, sorry for the confustion
Old Feb 23, 2004 | 06:22 AM
Sorry it's taken so long to reply......We've redeployed out of Iraq
( 173rd Airborne Brigade out of Italy) anyways..Is it highly unlikely that anyone will produce new rotor's- like pistons with variable ratios??.......Will There ever be a safe (renesis rotors are thin enough) way to lower the compression... I dont want to push alot of boost and I'm not looking for sky high hp #'s just a real performing street car... thinking about putting one of those disco-potato turbos on
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
jamespond24
Dec 1, 2015 11:11 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
pjwermuth
Sep 28, 2015 11:36 PM
