noise on startup?
Old Feb 13, 2004 | 08:45 PM
KARCPA's Avatar
noise on startup?
has anyone heard a short "wooping"noise on start-up. happened twice today and never heard it before...it was a hot38 degrees and had the a/con when starting....
Old Feb 13, 2004 | 10:22 PM
takahashi's Avatar
I start the car up when it was 43!!! 43 degree today!!
Sorry... could you elaborate much more about the noise? The only close to "wooping"noise is the rotary sound.
Old Feb 13, 2004 | 10:36 PM
Hymee's Avatar
Race Steward
43! No wonder they reckon it is hot at the MCG...
Need more info on the "woop-****" noise It is normal for them to rev a bit ruaciously at a cold start, but I'm not sure about wooping
Old Feb 14, 2004 | 01:32 AM
pricer01's Avatar
ANY SIGN OF HOLLERING ?????
Old Feb 14, 2004 | 01:51 AM
KARCPA's Avatar
definately not rotary sound ( iknow this sound after 3000k/m)
very hard to describe...it got to 43 degress (according to car..accuracy uncertain) ...has not happend again
like a high pitched whistle for about 2 secs
who knows maybe i got heat stroke!
Old Feb 14, 2004 | 08:05 AM
jeffneil's Avatar
Greetings All,
I was told that from about 5000kms (from memory - could be less kms) it will give a chirp on startup that is always with you from then on - the service guy called it the 'renesis chirp' and I think it has something to do with the ceramic seals in the engine.
That's what I can remember about it - back from early September when we got our 8. I'm sure the more technical people here will know all about it.
We have nearly 5000kms on ours and no chirp yet.
Jeffneil
Old Feb 14, 2004 | 02:22 PM
Hymee's Avatar
Race Steward
I'm on 15,000 km and I think TImbo is over 20k.
The only chirping mine does is from the tyres
Could it be the AC compressor clutching in? I'm sure it would be de-clutched at start, then moments later it would cut in, possibly a reason for a short high-pitched "squeal".
And I thought the ceramic seals were in the 26B le-mans engines, not the Renesis? I thought we had electron beam treated metal ones, chill filtered :p Anyway, my nice RX-8 book is with a friend ATM, so I can't check
Cheers,
Hymee.
Old Feb 14, 2004 | 04:44 PM
Wildcard's Avatar
NT Rotorhead
The Apex seals are made from Acicular cast iron (from the book). Hymee's memory is correct - they are tip electron beam chill hardened too.
It's disturbing the way some Mazda employees BS the general public. That service guy sould know that the Renesis doesn't have ceramic apex seals.
And the 'renesis chirp' is a new one to me. Never heard it. I think we can safely say now from our combined experience that there are no "ECU flips" at 5, 10, 15 or even 20000km.
Old Feb 14, 2004 | 09:24 PM
timbo's Avatar
rock-->o<--hard place
Yep -- no 'chirp' from mine after 22K. Are we talking about the ABS self-test 'grumble' that occurs just as you move off after starting? More information needed!
Also, I must say I am noticing more gearbox noise - almost turbo-like whistle, but that's at speed, 3rd-4th type changes
Old Feb 15, 2004 | 02:53 AM
Kev's Avatar
Kev
[rapidus octus]
I had a shocker the other day. Kicked it over and it sounded like an old cement mixer for 10~15 seconds. Never had the problem again - but I'll mention it at the next service.
Old Feb 16, 2004 | 05:02 AM
Hymee's Avatar
Race Steward
So how does the old cement (concrete ) mixer sound?
Old Feb 16, 2004 | 05:16 AM
pricer01's Avatar
My experience is like Hymee's, the only chirps are from the tyres and the occassional passenger not used to the cornering performance
One question needs to be asked though... has the cat's disappearance strangely coincided with the whooping noise?? A case of the cat seeking warmth under the bonnet maybe???
Rob
Old Feb 18, 2004 | 04:59 AM
KARCPA's Avatar
i'll go along with hymees theory of the a/c clutching in... i feel it was this althoug never heard it again
Old Feb 18, 2004 | 05:06 AM
RXE16T's Avatar
'RX-EIGHT'
Not too familiar with rotary engines, but it seems both the engine and drivetrain create a fair bit of "aural concern".
Fairly unique noises at that, since I've driven a lot of cars and some of the sounds that emanate from the 8 I've never heard before.
Just part of the car's charm I guess.
Mane
Nov 20, 2015 12:16 PM
nowakm99
Oct 9, 2015 07:10 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
neoksk
Sep 21, 2015 12:31 PM
