Search is NOT helpful
Old Feb 11, 2004 | 07:48 AM
Spin9k's Avatar
Momentum Keeps Me Going
You know, this search function really needs some adjustment.
I put in: "Stage 1 dyno"
and I get back that I need to use words with 3 letters or more. WTH ?
How are we supposed to search if simple queres don't work?
Is there a fix?? Why does it have to (NOT!) work this way?
Also this site is so slooooowwwww lately. What happened?
Old Feb 11, 2004 | 08:24 AM
Jeff_pap31s's Avatar
Here this should help:D
Old Feb 11, 2004 | 09:46 AM
Genom's Avatar
Not so Super right now
I think you just happened onto one of those bad terms for searching. Usually using teh boolean modifiers works pretty good for anyting I've needed to find.
Old Feb 11, 2004 | 11:21 AM
eccles's Avatar
Prodigal Wankler
Unfortunately, the wildcard feature is still fundamentally broken - any query that includes a wildcard returns ZERO results. Try "stage and dyno" vs "stage and dyn*" for example.
IMHO this is even worse than the three-character restriction, because it precludes searching for variants on a word in a single query, as in rattl* to find all the threads on rattle, rattles, rattled and rattling.
Old Feb 11, 2004 | 11:50 AM
Spin9k's Avatar
Thanks Jeff_pap31s!
You're the best search engine ever!
Old Feb 11, 2004 | 11:54 AM
Thumbs up
Originally posted by Spin9k
Thanks Jeff_pap31s!
:D I know:D
Your lucky I saved that dyno Maurice emailed me. I knew I saved it for some reason! LOL
Old Mar 18, 2004 | 10:21 AM
bowman's Avatar
Most of the time that I try to perform a search, I receive the message saying that I can only perform 1 search every 20 seconds.
What causes this?
Is the search function not Linux friendly?
Old Mar 19, 2004 | 11:08 AM
How many searches do you do?
Old Mar 19, 2004 | 11:30 AM
wakeech's Avatar
mostly harmless
btw, the problem with the original search is that the engine takes each term individually (obviously) and "1" is not a three letter word (as is the minimum).
Old Mar 19, 2004 | 08:05 PM
downshift's Avatar
<p><
What causes this?
I think it's a normal function to limit people from overloading the server from frequent searches.
Old Mar 19, 2004 | 08:26 PM
zoom44's Avatar
type Stage1 or CZStage1. without the space that should find you the threads.
Old Mar 20, 2004 | 12:27 AM
bowman's Avatar
downshift
Jeff_pap31s
I understand the purpose of that feature. What I am saying is that it has problems. I can sign on to the forum and I get that message for the very first search I try to perform.
Old Mar 20, 2004 | 08:07 AM
B-Nez's Avatar
When you click "View New Posts" or, when not logged in, "Today's Active Threads", that uses the search engine. You have to wait before doing another search.
drebbrnator
Dec 27, 2018 07:02 PM
Dokuji
Nov 1, 2016 02:51 PM
HMSS013
Aug 28, 2015 03:02 PM
patjza80
Aug 26, 2015 02:49 PM
MarkX
Jul 31, 2015 07:50 AM
