What is an acceptable AFR Air to fuel ratio
Old Aug 26, 2010 | 09:26 PM
EdwardLenczowski's Avatar
I own a cobb access port and it been reading my afr as 14.5 - 15.5 at idle generally. Is this rather high or am i a little paranoid. Im running mazda maniacs base tune for my year. Help Please?
Old Aug 26, 2010 | 10:24 PM
Charles R. Hill's Avatar
Owner of BHR
Yes, you are being paranoid.
Old Aug 26, 2010 | 10:36 PM
Thank you charles!
Old Aug 27, 2010 | 08:24 AM
fastlaneracing's Avatar
Rotor User
Whats your AFR at wot?
Old Aug 27, 2010 | 08:48 AM
DarkBrew's Avatar
Extraordinary Engineering
+1
Log a pull to redline on your AP, upload the data, plot it in excel and post an image of the graph.
Old Aug 27, 2010 | 09:33 AM
chonniedotcom's Avatar
My log shows a AFR at WOT as 11.7.
That's alright? Still totally stock.
Thanks.
Old Aug 27, 2010 | 02:29 PM
czar's Avatar
Almost boosted
sounds fine
Old Aug 27, 2010 | 05:21 PM
hakuna matata!
Thanks.
Thats actually a nice relatively lean mixture for being stock.
I've seen stock Mazda maps produce 10's at WOT.
Old Aug 27, 2010 | 06:39 PM
Afr 11.7
Just to be clear... that is with MM base map, on totally stock engine... no mid pipe....yet ;-)
I did not measure that with the Mazda stock ecu... not sure how to do that? as I had to load MM base tune map to get the the Access Port to log anything.
Old Aug 27, 2010 | 09:47 PM
DarkBrew's Avatar
Log it for us!
You datalog AFR and other stuff - You need to practice data logging anyway.
Plug AP into your computer
Transfer the datalog
Open in excel - if you don't have excel then download Java office suite for free
Create a chart
alt-Print screen
Paste in paint
Save as jpg
Post picture
Old Aug 28, 2010 | 02:10 AM
Will do!!! not at the right PC at the moment.. but will fer sure... :-)
Originally Posted by DarkBrew
Log it for us!
Open in excel
Create a chart
alt-Print screen
Paste in paint
Save as jpg
Post picture
Old Aug 28, 2010 | 10:17 AM
Picture of log
I could not figure out how to chart it properly... I would get a nice line showing the RMP, but other values would be burried at the bottom and would not show any usable data.
Old Aug 28, 2010 | 10:56 PM
ronx8's Avatar
zoom zoom!
i usually get low 12's at WOT
Old Aug 28, 2010 | 11:01 PM
hakuna matata!
that's 11.1 not 11.7
Old Aug 28, 2010 | 11:34 PM
Flashwing's Avatar
3-wheeler
This is a pretty big topic and not one that has a definitive answer. There is not really an "ideal" air/fuel ratio because a proper ratio will vary based on RPM and calculated load. What is considered proper is going to depend on your fuel octane, ignition timing and current operating conditions of the motor.
The MazdaManiac base calibration does not make any changes to the stock fuel tables so what you are seeing is the stock fuel settings for the RX8. MazdaManiac is well aware of what air/fuel rations are optimal for the performance of the vehicle based on your modifications so you have nothing to worry about.
Old Aug 29, 2010 | 01:02 AM
Loaded first map...
I took the base settings and increased the RPM limiter and adjusted the idle up about 30 rpm to see if it makes any differance.
RMP's are now hitting 8500 vs the 8000 limit as stock. Idle did not seem to change. At least I could not notice.
Gonna play a bit more tomorrow after I get my midpipe on... I got the stock pipe out this evening without any issues. Bolts looked like new....no rust!!! Crazy for an 04.
Cat also appeared to be in good shape, maybe it was recently replaced? Car is new to me only 3 months ago... so who knows. The screen in the cat had very little deposits on it... Will take a picture later.
Will log more tomorrow... see where I land. Go for a good cruise, hit different RPM's and loads.
Old Aug 30, 2010 | 04:04 PM
Did another drive and logged...
Hey gang...
Did another drive on the highway yesterday....
Attached are some screen shots:
Fisrt pick is a 2nd gear pull WOT
Second is a 3rd gear pull at WOT
Mods done:
Agency Power twin res midpipe, K&N airfilter. 2004, 4 speed AT tranny.
This is the first run of a stock map just loaded with max RPM's increased to 9000, Thats it.
I am thinking that I should see a higher mass airflow? maybe not? Stock airbox used.
Also... is 11.17 a good AFR for that type of engin operation? Should I not want that a bit leaner?
I will keep this map on for a few more drive cycles see if anything changes...
Any coments???
Old Sep 4, 2010 | 05:37 PM
8upbad's Avatar
Jared
Awesome thread, thanks for sharing!
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
