Welded Diff options?
Old Jul 30, 2010 | 09:30 AM
JPotta's Avatar
MN Welded Diff options?
Sorry I tried searching but couldnt find much. I would really like to put a welded diff in my car. Are there any open diffs that fit our car, or did any of the AT's come with open diff? Thanks in advance.
Old Jul 30, 2010 | 09:35 AM
Why would you want a welded Diff in your car
There is no situation in a car where that would be ideal..........
You can buy very nice 1.5 and 2 way LSD units that will effectively do similar..and still function properly
Old Jul 30, 2010 | 10:06 AM
fuztupnz's Avatar
Phone Booth'd
I'm guessing you want welded for drifting?
Do as Dannobre said and look into 1.5 or 2 way lsd's. A welded diff will give you nothing but problems like broken axles and will be terrible for driving on the street. A welded diff makes the car extremely hard to turn. The only use for one is for off-roading, but even those guys stay away from it unless all they do is mud running or straight hill climbing.
Old Jul 30, 2010 | 10:40 AM
Loki's Avatar
Please don't massacre your car like that :S
Old Jul 30, 2010 | 10:51 AM
JPotta's Avatar
Yea I understand its not ideal but its all i can afford right now and its better than this **** vlsd. jp
Old Jul 30, 2010 | 12:34 PM
Better for what.....
It's not better at anything except breaking **** and making your car damn near undriveable on the street
I had an ice racer that we did that in for a "chump car" type racing series...and it ripped itself apart after one race on ice.....imagine what that will do on the street...
And when you break the diff...and likely axels and other bits....how much do you think that will cost???
I would think a proper LSD would start looking cheap by comparison
Old Jul 30, 2010 | 12:38 PM
mike[piston eater]'s Avatar
O' Let's do it.
its drfting welded is common practice
Old Jul 30, 2010 | 12:39 PM
jasonrxeight's Avatar
stock isnt VLSD persay
and welded diff you get understeering
Old Jul 30, 2010 | 12:41 PM
^On a car that is trailered to the track and not street driven.....
There is nothing that makes a welded diff safe or driveable on the street..
And it is a ghetto fix for doing the right thing at best.....
Old Jul 30, 2010 | 12:42 PM
I doubt that it would understeer......think about that for a sec...a drift car that understeers
Old Jul 30, 2010 | 12:43 PM
O' Let's do it.
i will agree a welded diff on the street is dumb ive seen guys spin on the freeway cause they have run welded diffs
Old Jul 30, 2010 | 12:49 PM
a drift car oversteers when the rear wheels are spinning because of the low traction on the rear.
when the rear wheels are gripping you get understeer.
Old Jul 30, 2010 | 12:54 PM
a drive car oversteers when the rear wheels are spinning because of the low traction on the rear.
God...where do I start
I think I'll stay out of this one
Old Jul 30, 2010 | 12:57 PM
O' Let's do it.
ive driven 240s with welded diffs no understeering it is trying to oversteer with the littlest steering imput
Old Jul 30, 2010 | 01:02 PM
was it a power on into a corner or was it a off power into the corner?
I feel when off power turn in the corner, locked would give me a bit of understeer, and open diff would give me a bit of oversteer. as you get on power its the opposite. thats why LSD is for.
neofreak's Avatar
Stock isn't VLSD period. We have torsen differentials, not viscous.
Old Jul 30, 2010 | 01:03 PM
O' Let's do it.
it was just normal driving was trying to get used to my friends car at el mirage so i was getting a feel for how it was lol
Old Jul 30, 2010 | 01:58 PM
paulmasoner's Avatar
Asshole for hire
what OEM is, and banter about under/oversteer is all beside the point. the point is, if for some reason you are going to do this, you'll likely have to figure it all out on your own. i doubt you'll find much support or help here for making such a dumb move
Old Jul 30, 2010 | 01:59 PM
O' Let's do it.
kaaz 2 way is pretty afordable like 900 to 1k
Old Jul 30, 2010 | 03:04 PM
JPotta's Avatar
I guess I just assumed the stock diff was vlsd but either way it doesnt always lock up when I need it to. At least four of my friends daily drive on welded diffs a 240, miata, rx7 they all seem to have no problem, I only have a half mile drive everyday so im not really worried about it. I'm not trying to get into if its right or not just if there is anything I could possibly use.
Old Jul 30, 2010 | 03:14 PM
Asshole for hire
read the last 2 sentences of my last post...
Old Jul 30, 2010 | 03:18 PM
O' Let's do it.
you could gut the internals of the lsd and still weld it some people with fcs have done that to there turbo2 diff
Old Jul 30, 2010 | 03:22 PM
what do you mean lock up when you need them too?
LSDs dont "lock up", they transfer torque from one side to the other. some are very aggressive even transfer more torque to the outer wheel than welded diff.
if you want loose rear end, put stiffer sway bar in the back
Old Jul 30, 2010 | 03:29 PM
zoom44's Avatar
i have to admit something here- i never even heard of this until this thread. so i did a little research.
its the stupidest thing ive ever heard of if you want to drive your car on the road ever. if you do it you will wreck your car and die on the highway. you got a family? think about it.
plus you asking this and you didnt even know what you had already. go ask your friends that have theirs welded to help you. other wise go get get the 1.5 or 2 way. even better- use the money for some driving/drifting classes/lessons.
Old Jul 30, 2010 | 03:33 PM
FastFreddy61's Avatar
Its your car, if you want to stick a welded diff in it,do it .I had an '85 Z28 BBC with a spool, it was fun to drive and never had a problem, but remember, it will step out in slippery conditions,and the DSC will not function effectively , its a shame they dont produce a Detroit Locker for the 8,
PS. dont listen to morons who dont know **** from clay. stupid ppl suck.
