How to paint interior pieces
Old Jul 28, 2010 | 09:39 AM
nickraft14's Avatar
Can someone give me a link on where to buy lightning yellow paint , and instructions on how to sand, paint, and clear coat interior pieces? Thanks
Old Jul 28, 2010 | 10:39 AM
terch1's Avatar
I wouldn't do that. The interior of the 8 is nice as is. Interior pieces painted are not going to hold up they are going to get scratched, crack, and flake over time. Its just not a good idea which is why it is typically only done to cheap civics by young kids.
Old Jul 28, 2010 | 04:58 PM
Mawnee's Avatar
I divide by zero
Actually alot of Vette guys do it with some very nice results.
Old Jul 28, 2010 | 05:12 PM
vincephan's Avatar
You might wanna contact this guy...
https://www.rx8club.com/showthread.p...nterior+pieces
He did a great job painting his interior.
Old Jul 28, 2010 | 07:00 PM
Spin9k's Avatar
Momentum Keeps Me Going
Where to get paint ---> Automotivetouchup.com ... Use an adhesion promoter for the plastic bits, no sanding needed.
Old Aug 1, 2010 | 06:52 PM
2010rx8's Avatar
fantittytastic
If you want it done right and to last go to a professional body shop to paint it. If your hard headed and want to do it yourself cause nobody can touch your precious 8 follow these directions.
1. Remove pieces and scuff them up lightly (don't sand hard!) with 200grit sandpaper.
2. Go to a autobody supplier and buy yourself some SEM high build primer.
3. Coat the piece lightly and let it dry to see where you scuffed unevenly.
4. Scuff uneven parts if needed.
5. Clean with mineral spirits and terry cloth (leaves no hairs).
6. Spray part 3 more times.
7. Sand with 400 grit LIGHTLY and clean.
8. Sand with 1000 grit LIGHTLY and clean.
9. By now your part will look like glass.
10. Go to professional body shop to spray it. DO NOT buy paint and do it yourself unless you can spray. and for god sakes don't go to maaco.
11. Tell the body shop your color code and to clear it twice or more depending on how shinny you want it.
12. Your parts will look absolutely amazing and hold up for a while unless you hit it.
This is the process I follow when I do all my customers custom fiberglassing.
Good Luck. It takes patience but well worth it in the end.
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
nferguson88
Oct 6, 2015 12:45 PM
SimonT182
Oct 2, 2015 10:33 AM
Quiggs321
Sep 30, 2015 05:34 PM
GK1707
Sep 27, 2015 07:33 PM
