rattling from clutch
Old Jul 13, 2010 | 03:07 AM
rotary-ed's Avatar
so i made the grave mistake of trying to teach my friend how to drive stick in my 8 she kept stalling and bogging and what not. no when i got home and im parking up hill in reverse at really low rpms [below 1k]when i have the clutch in and it makes some rattling from the transmission area. im thinking its the throw out bearing but not 100 percent on that. what you guys think? mounts maybe? oh and if it is the throw out bearing does mazdas powertrain warranty cover it since im still on it? ahhh im seriously having an anxiety attack
Old Jul 13, 2010 | 03:12 AM
Jon316G's Avatar
Grasshopper
If it was a bad release bearing (aka throw-out bearing) then you'll notice the sound more when the clutch pedal is pressed in since that is when the bearing is actually being used.
One possibility is the release bearing tapping against the pressure plate.
But the tapping could also be something else under the car like the exhaust or heat shields.
Jack the car up and climb underneath with the vehicle running (have glove on) and see if its something else rattling.
Old Jul 13, 2010 | 03:20 AM
rotary-ed's Avatar
well the clutch pedal is pressed in just enough so the car slowly moves up before it stalls. if it is just tapping is it covered by mazda? but it really doesnt sound like tapping. it sounds like rattling like if the clutch is loose or some thing
Old Jul 13, 2010 | 03:41 AM
Jon316G's Avatar
Grasshopper
Does the tapping occur with the pedal all the way in or out?
Old Jul 13, 2010 | 01:44 PM
rotary-ed's Avatar
it happens when the pedal is in and i bring the rpms super low. like when the car gets shaky befor it stalls. i know that chirping noise from the trow out bearing and its not that
Old Jul 13, 2010 | 02:07 PM
Winning 8's Avatar
Hot Pit
I think it's the motor mount..
Old Jul 15, 2010 | 11:05 AM
SiX's Avatar
SiX
motor or transmission mount
Old Jul 15, 2010 | 12:59 PM
djvinniev77's Avatar
i just had my clutch replaced and started hearing this rattle.. turned out to be the heat shield all across the exhaust. my muffler guy wrapped some ties around them and have been fine so far..
the key thing for me was that it doesn't happen all the time.. you can check and see if yours is the same, and the muffler guy did just that, with car running and jacked up, he was tapping on the exhaust with a gloved hand and noted the shields rattle.
Old Jul 15, 2010 | 06:50 PM
RotaryRabbit's Avatar
i have the same problem with my heat shield, is it an easy fix for a guy that has little to no automotive knowledge?
Old Jul 16, 2010 | 07:34 AM
It looks easy if you work on mufflers all day. My local muffler shop saw it and had the ties. he was able to hoist the car up and was easy for him to tie and lock it. the ties are the industrial grade units you see sometimes tied up to boxes to secure packaging, not plastic or it will melt.
The key is to get it around and tie it down nice and tight.
RevMeHarder
Jun 1, 2026 02:30 PM
theblinkof
Oct 4, 2023 05:24 PM
Mane
Nov 20, 2015 12:16 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
