CODE p0850 HELP Please
Old Jul 12, 2010 | 10:12 PM
NYC Drift King's Avatar
Supercharged by Pettit
Question CODE p0850 HELP Please
OK listen I researched the code p0850 here on the forums. I found nothing useful, but people saying to change the Neutral switch input circuit on the tranny. Where exactly is the switch on the tranny? Does anyone have a picture? Is this the reason why my cruise control isn't working?
On the tranny i saw 2 white female and 2 black female connections. And the harness that connectes to the tranny had 2 white male and 2 black male connections. Does it matter which white to the white is connected? same question for the black?
Any help would be awesome thanks
edit:
Problem fixed =]
Ok I jacked up the car.
Disconnected the ---Neutral and reverse switches on the driver side of the tranny--
Next I cleaned them up with a spray to clean electrical connections.
then i swaped them. White to the other white. And black to the other black.
I also used a Multimeter but i didn't get the same readings as the link above. Mine just read 1.
(https://www.rx8club.com/series-i-do-yourself-forum-73/diy-test-neutral-reverse-switch-200453/)
So i put everything back nice and snug.
--AND-- problem fixed. No cel and Cruise Control works.
My advice. when disconnecting the Neutral and reverse connections from your tranny. Mark them even though you probably dont really need to. there color coded. white to white etc. And clean the connections before you reinstall them.
Old Jul 12, 2010 | 10:54 PM
the neutral switch?
I forgot the connector color. but its on the side of the tranny. somewhere above & after the tranny oil fill hole. so that means yes its on the driver side.
Old Jul 13, 2010 | 08:15 AM
Thanks NYCGPS
I didnt know those wires were the netural switch. I dropped the tranny and swaped flywheel/clutch this weekend myself with big massive help from my friend dave. Ima post a thread on it later. But those wires aren't marked. FML i guess its trial and error time.
Old Jul 13, 2010 | 08:18 AM
Jon316G's Avatar
Grasshopper
See if this is any help:
https://www.rx8club.com/showthread.php?t=200453
Old Jul 13, 2010 | 08:56 AM
Originally Posted by Jon316G
That does help. But if one of the colors show up not good then how do you replace? Does this Affect cruise control?
Old Jul 13, 2010 | 09:19 AM
Ok so the wires are the switch its all one unit. And so far found some threads this N switch can affect the CC.
Old Jul 13, 2010 | 09:53 AM
hakuna matata!
of course it can, remember the cruise control is tied into all of this. this way if you ever move your shifter while in cruise, it automatically deactivates.
those wires aren't marked and I believe they will go in either way... so they can definitely be hooked up wrong.
im going to be a doing a clutch install on sunday, so ill have to look out for this
Old Jul 13, 2010 | 11:47 AM
Talking
Problem fixed =]
(https://www.rx8club.com/showthread.php?t=200453)
Shankapotamus3
Mar 14, 2021 03:53 PM
jamespond24
Dec 1, 2015 11:11 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
tommy26Germany
Sep 29, 2015 10:33 AM
