How to fix Air Conditioner unit?
Old Jul 10, 2010 | 04:24 PM
Boom3k's Avatar
From: Los Angeles California Crenshaw District Cuhz..
Question How to fix Air Conditioner unit?
Yesterday while I was driving doing about 60 I noticed that my car was no longer blowing cold air. I meant it completely stopped. Usually when I turn my A/C on my car will almost instantly blow cold air but now the car won't even make a noise to show that its on. Now my question is how do I recharge this baby. Don't say a shop because I'm in Los Angeles and these people are crooks. Also, I have worked on ky car before so all I need is some instructions/suggestions. Please no BS because its too hot for this right now.
Old Jul 10, 2010 | 04:50 PM
ken-x8's Avatar
If it suddenly stopped cooling the problem may be something other than charge. The usual DIYable low charge comes from a slow leak and the AC becoming wimpier over time.
You said there's no noise. Does the fan blow? Does the compressor clutch engage? If the compressor clutch does not engage, check the fuse. If the fuse is OK, put a pressure gauge on the low side fitting to see if there's any charge. (Or just momentarily push in the pin on the valve to see if something comes out.) If there's no pressure at all, then it's likely you took a rock through the condenser, or had some something equally catasrophic.
If there's some pressure, you can buy refrigerant and an inexpensive pressure gauge at Wal-Mart, Autozone, etc. That will come with summary instructions on charging.
Ken
Old Jul 10, 2010 | 05:21 PM
Boom3k's Avatar
@Ken Dude we just checked and the ac unit isnt even clicking on. We checked the fuses and everything. I might have a busted AC unit.. (Crying)
Old Jul 10, 2010 | 06:02 PM
EDZRIDE's Avatar
2005 White GT
Try recharging it but like Ken mentioned it's probably a catastrophic failure.
Old Jul 10, 2010 | 07:44 PM
Boom3k's Avatar
Heres the problem.
http://www.youtube.com/watch?v=427T5dW86Cw
Old Jul 10, 2010 | 07:51 PM
Boom3k's Avatar
just checked the pressure by pushing in the pin and got no kind of pressure. Now my next question.. WHAT NOW??
Old Jul 10, 2010 | 09:12 PM
ken-x8's Avatar
You told us to not say "Take it to a shop." That kind of limits it.
No pressure means no refrigerant. That's why the clutch doesn't engage: there's a low pressure safety switch. Losing refrigerant that quickly means something significant is wrong. Maybe a blown compressor (seal failed) or a rock through the condenser.
I'd cry, too.
Ken
JimmyBlack
273
Feb 10, 2020 10:23 PM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
RenzoRx-8
Sep 9, 2015 02:38 PM
mattymack
Sep 6, 2015 10:33 PM
