Engine gets really hot!!! Please help!
Old Jul 4, 2010 | 11:34 PM
richyrx8's Avatar
Exclamation Engine gets really hot!!! Please help!
OK so i have a 2005 manual, i changed de spark plugs, i´m getting new coils and i changed de cat for a mid pipe... at fist the cat was wetting really hot, the car was losing power going uphill and for a long distance (for example when driving from the ariport to the city) that's why i replaced the cat but that did't work... the whole front of the car gets really hot! the temperture nedle doesn't go up so i'm guessin the engine temperture it's fine BUT still... under the hood gets extreamly hot!! is that normal?? any ideas???
Old Jul 4, 2010 | 11:38 PM
jasonrxeight's Avatar
its normal
sometimes when its REALLY hot, the fans would keep spinning when you turn off the car.
Old Jul 5, 2010 | 04:27 PM
quazmosis's Avatar
Chode
As long as your default temp gauge sits at about 2.5 ticks to the left of the middle, your completely fine. As soon as it moves farther to the right than that its too late.
Old Jul 6, 2010 | 01:04 AM
richyrx8's Avatar
The temp gauge it's right in the middle... i've heard the fans working after i've turn off the car a few times... so i'm guesin' that my car's alright...thanks for your help guys!
Old Jul 6, 2010 | 06:53 AM
Eish's Avatar
your car is really hot !
Old Jul 6, 2010 | 09:20 AM
quazmosis's Avatar
Chode
NO you're not fine if its right in the middle. Perhaps check your coolant or get a coolant change. It should not be directly in the middle. 2.5 ticks to the left is the norm. Middle bad, Right even worse.
Old Jul 13, 2010 | 11:42 PM
MazdaRX-8SPEED's Avatar
White Eagle
well then why is he losing power going up hill? cause im having same problem but my gauge is a line under mid..
Old Jul 14, 2010 | 12:34 AM
Learn how to read!
He told you, he replaced the CAt and it works fine.
Now go get your self a hunting dog!
Old Jul 14, 2010 | 08:45 AM
White Eagle
damn! i misread...
Old Jul 14, 2010 | 09:25 AM
RMXG8's Avatar
mine gets to about 233 and thats alittle pass half and cools itself back down but that at like 115 deg out the dealers said it was fine as long as its not pinned at hot and it cools back down.
vapor2
Nov 3, 2020 03:38 PM
madrotor
Jul 26, 2015 12:06 PM
dbarber
Jul 25, 2015 01:34 PM
Belalnabi
Jul 22, 2015 04:50 PM
