mid pipe hi flow cat
Old Jun 29, 2010 | 10:32 PM
calej729's Avatar
NJ mid pipe hi flow cat
ok i want to get a mid pipe i already have a greddy sp2 and aem cai but i heard that getting a mid pipe will void warranty if this is true will a hi flow cat void the warranty or will the hi flow cat be ok?
Old Jun 30, 2010 | 04:02 PM
BJP's Avatar
BJP
your probably going to get pounded with "use the search button". from what I have seen you will get a check engine light if you remove your cat... not sure on the warranty though, but I'm sure it would void it.
Good luck
Old Jun 30, 2010 | 04:06 PM
NautyOne's Avatar
Touge Addiction
I'll bite.
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/important-information-all-modders-104756/
Old Jun 30, 2010 | 04:19 PM
1. why do you want a midpipe? What are the emission laws in your state governing the catalytic converter? You do know it's against Federal Emission Laws to remove the OEM catalytic converter, right?
2. you WILL get a Check engine light if you remove it.
3. As for voiding your warranty: look at the thread above but also see the last part of my first bullet point.
Old Jun 30, 2010 | 04:40 PM
Grog's Avatar
I don't think a high flow cat will throw you a CEL, but you won't get the HP you'd get from a midpipe, or the sound (Which might be what you want; I dunno). Midpipes make everything ******* LOUD unless you get a dual resonated. Sometimes they attract the wrong type of attention unless you go out of your way to find a quieter one. They're illegal, yes, so you would have to swap to your cat to pass emissions tests, etc.
Old Jun 30, 2010 | 07:36 PM
the High flow cat shouldn't throw a CEL, I know I've never had one with my RP unit.
The HP difference between a midpipe and a car with a high flow cat is SO minnimal that I doubt most people would even notice.
Heck, the last 2 years I've done the SoCal dyno meet, no car WITH a midpipe (that was N/A) has gotten more hp then my car with a hi flow.
92trbolzr
May 18, 2025 09:04 AM
mdl0209
May 23, 2019 05:46 PM
XianUnix
Sep 29, 2015 03:48 PM
pjwermuth
Sep 28, 2015 11:36 PM
FubarI33t
Sep 28, 2015 08:45 PM
