intake manifolds
Old Jun 26, 2010 | 08:04 PM
kailua_chaos's Avatar
intake manifolds
Setting my car up for boost, curious what people are running in the way of intake manifolds on their 8's. Also curious about motor mounts.
Old Jun 26, 2010 | 08:12 PM
Mawnee's Avatar
I divide by zero
Most of us run the stock intake.
Old Jun 26, 2010 | 08:30 PM
another thing i'm kinda curious about is underdrive pullies. What kind of gains (if any) should be expected or is this generally unadvisable for 8's?
Old Jun 26, 2010 | 08:49 PM
laythor's Avatar
I zoom therefore I am.
i would suggest reading the "major horsepower" section of this forum
Old Jun 26, 2010 | 11:10 PM
two zero two's Avatar
Unregistered User
most people who get underdriven pulleys get the AP crank pulley, i sprung for the unorthodox racing 3 piece set. the gains are going to be nominal at best. if you were going to stay NA and have a couple hundred dollars just sitting around, i'd say do it and squeeze the most you could out of the engine, or if you are building a show car and want something flashy under the hood, then go for it. but compared to the gains you are going to get from FI, pulleys are not going to make a difference. i'd put that couple hundred towards turbo accessories or suspension parts. good luck with your build
Old Jun 26, 2010 | 11:29 PM
wcs's Avatar
wcs
no agenda
^^^ Agreed
I have a set of the SR Under drive pulleys and while I'm happy with the appeal ..... zero on the performance ... .... I might add....
That (imo) it reduced my idle quality while using the AC
Old Jun 27, 2010 | 12:05 AM
I ran AP pulleys on my turbo'd car...with a lot of extra electrical loads...the alternator had a difficult time keeping up at idle
I went back to stock crank pulleys and the alternator output is better for my needs
Old Jun 27, 2010 | 12:26 AM
WTBRotary!'s Avatar
Drummond Built
Dannobre.... do you like Smallville??? lol...
Old Jun 27, 2010 | 12:29 AM
I live in Smallville Where they filmed it anyway......
Sounds better than a small suburb of Vancouver
Old Jun 27, 2010 | 12:31 AM
WTBRotary!'s Avatar
Drummond Built
Thats so awesome... its beautiful there...
Old Jul 3, 2010 | 05:26 PM
Thanks for the info !! saved me a few hundred lol.
Old Jul 3, 2010 | 05:41 PM
Brettus's Avatar
Boosted Kiwi
Agree with Dan - I went straight back to stock pulley when I fitted the turbo .
The only documented change to the upper intake manifold was done by Esmeril racing when they were pushing 500whp .
Other than that it is common practice to use the AEM intake (pre turbo ) in Greddy builds .
Sato Tatsuya
Oct 5, 2015 03:09 PM
Zube6115
Sep 30, 2015 12:57 PM
Jb4ker96
Sep 27, 2015 10:06 PM
Evan Gray
Sep 26, 2015 12:30 PM
