Uh, there's a hole in my engine...wtf!
Old Jun 26, 2010 | 02:52 PM
RX8SaxMan's Avatar
Angry Uh, there's a hole in my engine...wtf!
So yesterday I took off my UIM so I could try to free up a stuck APV (which is now nice and easy to turn thanks to a mix of Seafoam and WD-40). I have 99,988 miles and this the first problem I've had, so no big deal. Anyway, I look down at the engine where it mates to the transmission and see a hole! I'm 95% sure that it is not supposed to be there, as it looks like a chunk of iron has been ripped off of it (see pics).
To my knowledge, the only time anyone has touched my engine there was when I got my clutch replaced at an independent shop out here. I would just go and yell at them right now, but the work was done way back in November 2008 and 20k miles ago so I'm not sure if I could even hold them liable anymore. It hasn't caused any issues so far, but I still find it concerning to have an opening into my flywheel/clutch area.
I've never dealt with something like this before. What would you guys do in this situation? Is it even worth pursuing, or does anyone have a suggested way to patch the hole so crap doesn't fall in it?
Attached Thumbnails Uh, there's a hole in my engine...wtf!-img_0976.jpg   Uh, there's a hole in my engine...wtf!-img_0977.jpg   Uh, there's a hole in my engine...wtf!-img_0978.jpg   Uh, there's a hole in my engine...wtf!-img_0979.jpg   Uh, there's a hole in my engine...wtf!-img_0982.jpg
Old Jun 26, 2010 | 02:53 PM
hakuna matata!
wow lol.
thats a first.
that is something unlikely to happen naturally.. im thinking they screwed something up when installing your clutch.
Old Jun 26, 2010 | 02:55 PM
RX8SaxMan's Avatar
Yeah no joke, I'm baffled as to how it could have even happened...
Old Jun 26, 2010 | 05:30 PM
Brettus's Avatar
Boosted Kiwi
Hard to see properly but looks like a piece is broken off the bell housing - likely caused by an impact while taking the g/box in or out ......
Old Jun 26, 2010 | 05:49 PM
Jon316G's Avatar
Grasshopper
Holy ****!
That 4th pic where you see the "N3H..." identification is the flywheel.
Yeah... likely occurred during the clutch install.
I would be concerned with any fluids running down there, especially with the oil filter right there!
BTW... no need to remove the UIM to access the APV since its on the lower part of the LIM.
But at least you got to find this!
Old Jun 26, 2010 | 07:13 PM
RX8SaxMan's Avatar
Originally Posted by Jon316G
Holy ****!
Haha yeah I know where the APV is, I just wanted to dump some Seafoam into all the chambers of the LIM in case any of the other valves were getting carbony. So yeah, oil hitting the clutch is my main concern. Any ideas how to cap the hole to prevent that?
Old Jun 26, 2010 | 08:25 PM
zoom44's Avatar
good call , ray. cranking on it to align everything would seriously stress it . enough to crack it and then over time it just fell off
Old Jun 26, 2010 | 08:37 PM
There is an access hatch there.......
****...looked at the picture again...It is broken
You likely can make the access cover a bit bigger to cover it..it isn't structural...but part of the iron is broken off
Attached Thumbnails Uh, there's a hole in my engine...wtf!-img00040.jpg   Uh, there's a hole in my engine...wtf!-img00038.jpg   Uh, there's a hole in my engine...wtf!-img00039.jpg
Old Jun 26, 2010 | 09:17 PM
RX8SaxMan's Avatar
My suspicion is that the shop tried using the bolt in that location to draw the trans to the engine, rather than properly align things first before expecting the engine and trans to mate properly.
Ah, that definitely sounds plausible. I wish I had looked it over in more detail right after the service was done...oh well, hindsight is always 20/20.
It's definitely broken, but that makes me feel better about it. I was thinking that whole section was busted off, but at least now I know that the amount of iron that broke isn't as much as I initially thought.
I think I'll try to finagle a way to cover it with some sheet metal or something to at least give it a little more protection from foreign objects/fluids.
Old Jun 26, 2010 | 11:30 PM
wow ... simply wow !
Old Jun 26, 2010 | 11:59 PM
Winning 8's Avatar
Hot Pit
I think they ply the tranny out without removing that bolt.
Old Jun 27, 2010 | 12:02 AM
There is just a small thin casting there that isn't structural....the nearest bolt is the one on the lift hook. Damn shame someone was careless...but it could have been a lot worse
Old Jun 27, 2010 | 12:57 AM
hakuna matata!
Learn something new everyday...
Old Jun 27, 2010 | 01:46 AM
It likely won't ever be a problem, the clutch area isn't sealed even when that piece isn't missing
Old Jun 27, 2010 | 07:54 PM
Turblown's Avatar
Boostin'
I've seen that before...
Threshermal
Apr 15, 2020 09:43 PM
arexatemate
Oct 28, 2019 08:16 AM
coolcars44
Sep 24, 2015 05:47 PM
