Clutch master/release cylinder
Old Jun 14, 2010 | 08:36 PM
Rx8Curacao's Avatar
Question Clutch master/release cylinder
My clutch is failing on me.
I am at the point of ordering a clutch master cylinder and a clutch release cylinder at Mazda.
Can anyone give me tips about things my mechanic should think of when he is gone do the repair?
Any tips on what is the best to order and where???
Rick
Old Jun 14, 2010 | 10:14 PM
why are you replacing the Clutch Master Cylinder ?
Clutch Release cylinder? I assume you're talking about the Slave Cylinder.
Both parts, there is no point to replace it unless it already failed, which hardly happens. (I was one of the unlucky one thats all)
Old Jun 15, 2010 | 10:21 AM
Rx8Curacao's Avatar
clutch
Thanks for your answer!! My clutch stays down on the ground when i push it down with my foot. I have to pull it up again with my feet.
So i assume the slave- and or mastercylinder have to be replaced???
Old Jun 15, 2010 | 06:06 PM
gareth's Avatar
There is a spring that should should be pulling your clutch pedal back up from the floor. This would obviously be the first thing to check as even badly failing clutch hydraulics wouldn't cause the pedal to stay on the floor.
Old Jun 15, 2010 | 07:32 PM
check ur clutch pedal first.
Old Jun 15, 2010 | 08:39 PM
alex zhuk's Avatar
ok guys i am having the a problem shifting into gears, i looked at my clutch pedal and saw that there was oil coming out of the pedal, i called and talked to a person that works on my car and he said the clutch master cylinder is failing...... should i replace the slave as well at the same time? also what else should or could i replace at the same time?
and where would be the best place to buy it?
thanks
Old Jun 16, 2010 | 11:10 AM
gareth's Avatar
thanks
First you should start a new thread.
Then you should replace the master and inspect the slave. Some say to replace both because if the master is failing the slave typically isn't far behind. But I don't like replacing parts that aren't already failing.
Old Jun 16, 2010 | 02:38 PM
alex zhuk's Avatar
my bad, i just thought we were talking about master/slave cylinders.. just had a quick question didnt think i had to start a new thread for a quick question.
where can i order something like that?
Old Jun 16, 2010 | 03:43 PM
Where do you buy food ?
Where do you buy TV ?
I mean, seriously, Mr. Obvious ?
Old Jun 16, 2010 | 05:03 PM
alex zhuk's Avatar
well ****, thanks for the help.....(NOT) of course i can go to the dealer ship and get it i was just seeing if there was anyone else i could give my money to other then that gay place...
dont gotta be so rude.
Old Jun 16, 2010 | 09:03 PM
you got 70 something post but it seems that you're worst than some newly registered n00b here.
How about search? or look thru the WHOLE DAMN SITE for clues ?
My god people.
theblinkof
Oct 4, 2023 05:24 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Stubbs
Sep 27, 2015 04:06 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
