Termite
02-02-2004, 09:28 AM
Right,
I've had the RX8 for about 3 weeks now (done about 900 miles in that time :D ). Anway I've now noticed a few things which I'm not sure I should go back to the dealer on. Being my first NEW car, not sure really how fussy I'm being on one point and whether the 2nd is expected and the 3rd is me not being used to the car.
Problem 1 - Where the bumper joins the chassis near the rear wheel arch, it sticks out a little bit, ie its not totally flush. Now its only out by prob 5mm . . and probably only noticable to me. Is this something I should take back and get them to fix? The other side is totally flush.
Problem 2 - When in neutral, with the clutch up, I can hear what I can only assume is the plates gently rubbing. I also find that if I'm down shifting at high revs, clutch down and knock into gear with clutch down I hear *something* speeding up as tho plates where still touching. When I put the clutch down in neutral the noise goes away. . forgot to add that bit :)
Problem 3 - Starting after rain and sometimes normally, I turn the key with clutch down (as per manual). Well it tries to start, and usually does after about 3-4 seconds (not the more or less instant I would have expected). Sometimes I have to use the throttle (as in a flood start) to get it started. It then coughs n splutters until it finally tics over. Now the engine isn't flooding from driving or switching off from cold.
So . . . all in all should I be going back to the dealer for all 3 of these problems? If not are there any I should worry about?
Thanks in advance.
Termite
Thanks in advance.
Termite
