Car locks, radio, nav don't work
Old Jun 5, 2010 | 11:07 AM
gusmahler's Avatar
Had a flood problem on Thursday and was finally able to get it to start today. But now there are problems that weren't there before. The radio doesn't work. The nav doesn't work, and the power door locks don't work. The accessory fuse looks fine. Help!
Old Jun 5, 2010 | 11:14 AM
gusmahler's Avatar
OK, locks work now. Nav and radio still don't work.
Also, the guages go all the way to max, then back down to zero, when I insert the key and turn it to ON (not to Start).
Old Jun 5, 2010 | 11:20 AM
Jon316G's Avatar
Grasshopper
Can you tell us what else works/doesn't work?
Interior lights?
Power and heated seats (if applicable)?
Power windows?
Sunroof (if applicable)
Outer Mirrors move?
I assume you have the gauges tapped into the cig lighter circuit... which tells us the ACC circuit is good.
You could be looking at the 30A BTN or 15A ROOM fuse... but if your locks work now, may not by the BTN fuse.
Old Jun 5, 2010 | 11:28 AM
gusmahler's Avatar
Now the locks don't work again!
Old Jun 5, 2010 | 11:31 AM
gusmahler's Avatar
Interior lights?
Power windows?
Outer Mirrors move?
Mirrors work.
Interior lights, power windows don't. Don't have power seats or a sunroof.
Old Jun 5, 2010 | 11:35 AM
Jon316G's Avatar
Grasshopper
Can your car start?
Old Jun 5, 2010 | 11:37 AM
gusmahler's Avatar
Car starts fine today (though not the previous three days.)
Also, the sun visor broke, which, according to other searches, may be the cause of the problem.
Old Jun 5, 2010 | 11:41 AM
Jon316G's Avatar
Grasshopper
I'm looking at the circuit for the power windows (eventually we'll get to an "intersection" where all these failed devices meet) and there are only a few fuses.
The 120A MAIN fuse... which can be ruled out if the car will attempt to start now.
The 30A BTN fuse... which is a very likely candidate.
And the 30A P WIND fuse... which is only for the power windows and won't affect the others.
I'll try to find where the visor circuit is just in case.
Old Jun 5, 2010 | 11:44 AM
Jon316G's Avatar
Grasshopper
OK... visor receives voltage from the 15A ROOM fuse.
The ROOM fuse receives voltage from the 30A BTN fuse...
I would check the BTN fuse AND the 15A ROOM fuse!
Old Jun 5, 2010 | 11:49 AM
chino0314's Avatar
its the 15a fuse same **** happened to me last week
Old Jun 5, 2010 | 11:50 AM
Jon316G's Avatar
Grasshopper
Can't just be the ROOM fuse if he doesn't have working power windows... different circuit.
Just look at the electrical diagram!
Not saying the ROOM fuse isn't blown... but I would also look at the BTN since that supplies voltage to the power windows AND the ROOM fuse.
Old Jun 5, 2010 | 12:01 PM
gusmahler's Avatar
Room fuse was blown. Replaced it and the radio and locks work.
Didn't check the windows, though. I'll check those. If they don't work, I'll check the BTN fuse.
Thanks for your help!
Old Jun 5, 2010 | 12:09 PM
gusmahler's Avatar
LOL, I'm an idiot. The power windows were turned off. They work fine. Thanks again for all your help
Old Jun 5, 2010 | 12:13 PM
Jon316G's Avatar
Grasshopper
LOL... its all good... glad everything is working now
Crazy.8
Apr 18, 2017 03:17 PM
JakeKaminskisRacing
Aug 23, 2015 01:10 AM
MolecularConcept
Aug 5, 2015 04:43 PM
thewatcher101
Jul 27, 2015 09:44 PM
Jmanie9515
Jul 20, 2015 07:29 PM
